ESP32 SD-Card Stream download, sd card failure?
Hello i have a problem with downloading a file from the internet to an sd card via an ESP32. The gettting the data from the stream works fine, but the writing to a sdcard doesnt work so well. It fails to write to the sd card at random moments and wont continue to write. Sometimes it succes to write all of it to the card with the same code. Could anyone help me, how to write streams continously to an sdcard?
download_sd(SD, "https://data-ssl.atudo.net/output/mobile.php?v=4&lat=52.51678333333333&lon=13.416493333333335&session=3da5ce70a1a17597@@@bd9a18ba-d33d-41d7-b44e-a071bf812d10&ver=3.7.6&cspeed=0&direction=0&key=d83nv9dj38FQ", "/test.sqlite");
void download_sd(fs::FS &fs, String url, String path) {
if ((wifiMulti.run() == WL_CONNECTED)) {
HTTPClient http;
http.begin(url);
int httpCode = http.GET();
if (httpCode > 0) {
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
  // file found at server
  if (httpCode == HTTP_CODE_OK) {
    int len = http.getSize();
    uint8_t buff[512] = { 0 };
    int c; //How many Bytes are read
    WiFiClient * stream = http.getStreamPtr();
    fs::File f = SD.open(path, FILE_WRITE);
    while (http.connected() && (len > 0 || len == -1)) {
      size_t size = stream->available();
      if (size) {
        // read up to 128 byte
        c = stream->readBytes(buff, ((size > sizeof(buff)) ? sizeof(buff) : size));
        Serial.write(buff, c);
        if (!f) {
          Serial.println("Failed to open file for appending");
          return;
        while(!f.write(buff,c)){
          Serial.println("SD-Card write failed");
          delay(100);
        if (len > 0) {
          len -= c;
      delay(1);
      f.close();
    Serial.print("[HTTP] connection closed or file end.\n");
  Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
delay(10000000);
delay(10000000);
Not related to your problem, but why do this ?
In any case
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
