imho spiest sich da was mit einem der Pins,
ich hab mal einfach alles auf Pin 5 gelegt, dann läuft es durch.
//Andrei Aldea 2018, based on code by Mel Lester Jr. , adapted for Clock Functionality and use on the ESP8266
//Please note this Code uses the RX pin as one of the outputs, so you cannot use the Serial COM on the ESP8266 in the code
// https://github.com/Grippy98/ESP8266-7-Segment-Display-Wifi-Clock/blob/master/ESPSevenSegmentClock.ino
#include <ESP8266WiFi.h>
#include <time.h>
// ESP8266 Compatible Pin Assignment
int aPin = 5; // A
int bPin = 5; // ________
int cPin = 5; // | |
int dPin = 5; // F | | B
int ePin = 5; // | G |
int fPin = 5; // |________|
int gPin = 5; // | |
int GND1 = 5; // | |
int GND2 = 5; // E | | C
int GND3 = 5; // |________|
int GND4 = 5; //
int dPnt = 5;// D O dPnt
int dig1 = 0;
int dig2 = 0;
int dig3 = 0;
int dig4 = 0;
int DTime = 1; //Delaytime for itterations, 16ms default, 4 ms now
const char* ssid = "xxx"; //Change the next 3 lines!
const char* password = "xxxxx";
int timezone = -5; //EST is UTC-5
int dst = 0;
int i = 0;
long timer = millis() + 500;
pinMode(aPin, OUTPUT);
pinMode(bPin, OUTPUT);
pinMode(cPin, OUTPUT);
pinMode(dPin, OUTPUT);
pinMode(ePin, OUTPUT);
pinMode(fPin, OUTPUT);
pinMode(gPin, OUTPUT);
pinMode(GND1, OUTPUT);
pinMode(GND2, OUTPUT);
pinMode(GND3, OUTPUT);
pinMode(GND4, OUTPUT);
pinMode(dPnt, OUTPUT);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
configTime(timezone * 3600, dst * 0, "pool.ntp.org", "time.nist.gov"); //Time server
while (!time(nullptr)) { //Wait for connection to get actual time
digitalWrite( GND4, LOW); //digit 4
pickNumber(0);
Serial.println("end setup");
// turn off all display digits
digitalWrite( GND1, HIGH);
digitalWrite( GND2, HIGH);
digitalWrite( GND3, HIGH);
digitalWrite( GND4, HIGH);
time_t now;
struct tm * timeinfo;
time(&now);
timeinfo = localtime(&now);
dig1 = timeinfo->tm_hour / 10; //Abusing integer math a bit to get the digits
dig2 = timeinfo->tm_hour % 10;
dig3 = timeinfo->tm_min / 10;
dig4 = timeinfo->tm_min % 10;
Serial.println(dig1);
Serial.println(dig2);
Serial.println(dig3);
Serial.println(dig4);
//The following code scans really fast throug the digits so it creates persistance of vision... aditional delays really screw with this.
pickNumber(dig4);
delay(DTime);
digitalWrite( GND3, LOW); //digit 3
pickNumber(dig3);
delay(DTime);
digitalWrite( GND2, LOW); //digit 2
pickNumber(dig2);
digitalWrite(dPnt, HIGH); //Middle decimal point always ON
delay(DTime);
digitalWrite(dPnt, LOW);
digitalWrite( GND1, LOW); //digit 1
pickNumber(dig1);
delay(DTime);
void pickNumber(int x) {
switch (x) {
case 1: one(); break;
case 2: two(); break;
case 3: three(); break;
case 4: four(); break;
case 5: five(); break;
case 6: six(); break;
case 7: seven(); break;
case 8: eight(); break;
case 9: nine(); break;
case 10: a(); break;
default: zero(); break;
void clearLEDs()
digitalWrite( aPin, LOW); // A
digitalWrite( bPin, LOW); // B
digitalWrite( cPin, LOW); // C
digitalWrite( dPin, LOW); // D
digitalWrite( ePin, LOW); // E
digitalWrite( fPin, LOW); // F
digitalWrite( gPin, LOW); // G
digitalWrite( dPnt, LOW); // DecimalPoint
void one()
digitalWrite( bPin, HIGH);
digitalWrite( cPin, HIGH);
void two()
digitalWrite( aPin, HIGH);
digitalWrite( dPin, HIGH);
digitalWrite( ePin, HIGH);
digitalWrite( gPin, HIGH);
void three()
void four()
digitalWrite( fPin, HIGH);
void five()
void six()
void seven()
void eight()
void nine()
void zero()
//The following isn't acutally used but you get an idea as to how you could implement a limited character set on these displays.
void a()
Mein Vorschlag wäre: hol dir ein LED Display, entweder ein MAX7219 (SPI) oder eins mit einem HT16K33 (I2C) braucht weniger Pins, und der ESP kann was anderes auch noch machen.
Edit:
int cPin = 9;
löst bei mir am NodeMCU einen WD Reset aus. eh klar, hätt’ mir gleich auffallen können.
