Examples > 07.Display > Bar Graph [code example]
The Arduino IDE provides a nice built-in example File > Examples > 07.Display > barGraph (https://www.arduino.cc/en/Tutorial/BuiltInExamples/BarGraph) to simulate a bar graph with 10 LEDs.
Here's how you can complete the example with a 4-digit, 7-segment LED display instead. [Note: For simulating a bar graph, the 4-digit, 7-segment LED display is more challenging to program than 10 LEDs. You should complete the built-in example first before building this "4-digit, 7-segment LED display" version.]
Hardware Required
  • Arduino Board (I used UNO)
  • 4-digit, 7-segment LED display
  • 10K ohm Potentiometer
  • 4 220 ohm resistors
  • hook-up wires
  • breadboard
Circuit (to enlarge: https://i30.servimg.com/u/f30/12/91/04/49/bargra13.png)
Schematic (to enlarge: https://i30.servimg.com/u/f30/12/91/04/49/bargra12.png)
Code
Pinouts are detailed in the header comment of this code. Before you build the "4-digit, 7-segment LED display" version of a bar graph simulator, you should read through the code, which is thoroughly documented.
  LED bar graph
  7-Segment LED Display
  Segment   UNO pin     LED pin
  a         2           11
  b         3           7
  c         4           4
  d         5           2
  e         6           1
  decimal   7           3
  f         8           10
  g         9           5
  D1        10          12
  D2        11          9
  D3        12          8
  D4        13          6
// these constants won't change:
const int analogPin = A0;   // the pin that the potentiometer is attached to
const int ledCount = 8;     // the number of vertical lines in the bar graph
  //Set D2-D13 as OUTPUT
  for (int i=2; i<14; i++)
    pinMode(i, OUTPUT);
    digitalWrite(i, HIGH);
void draw_digit(int digitPin, bool firstBar, bool secondBar) {
  // turn off all seven segments of the digit and the decimal point (not connected)
  for (int thisPin = 0; thisPin < 8; thisPin++) {
    // the seven segments and the decimal point are connected to UNO pins 2-9
    digitalWrite(thisPin + 2, LOW);
  // for all digits that are part of the bar gragh, the first bar is always lit
  if (firstBar) {
    digitalWrite(6, HIGH);
    digitalWrite(8, HIGH);
  // for all digits that are part of the bar gragh EXCEPT the last digit, the second bar is always lit;
  // for the last digit that is part of the bar graph, the seoond bar may or may not be lit
  if (secondBar) {
    digitalWrite(3, HIGH);
    digitalWrite(4, HIGH);
  // turn on the given digit in the 4-digit LED display
  digitalWrite(digitPin, LOW);
  // read the potentiometer
  int sensorReading = analogRead(analogPin);
  // map the potentiometer reading (range 0-1023) to a range from 0 to the number of LEDs
  int ledLevel = map(sensorReading, 0, 1023, 0, ledCount);
  // calculate the number of digits with both bars lit
  int fullDigits = ledLevel / 2;
  // determine if the last digit has both bars lit
  // partialDigit == 0 both bars lit
  // partialDigit == 1 only first bar lit
  int partialDigit = ledLevel % 2;
  // process each digit in the 4-digit LED display
  for (int thisLed = 0; thisLed < 4; thisLed++) {
    // if the digit is part of the bar graph and not the last digit
    if (thisLed + 1 <= fullDigits) {
      // light both bars
      draw_digit(10 + thisLed, true, true);
    // if the digit is the last digit that is part of the bar graph and only the first bar should be lit
    } else if ((thisLed == fullDigits) && (partialDigit == 1)) {
      // light only the first bar
      draw_digit(10 + thisLed, true, false);
    // if the digit in not part of the bar graph
      // light nothing in the digit
      draw_digit(10 + thisLed, false, false);
    delay(5);
    // turn off the digit
    // in the 4-digit LED display, only one digit can be lit at a time;
    // however, everything happens so quickly that our eyes think all four
    // digits are lighting simultaneously
    digitalWrite(10 + thisLed, HIGH);
The diagrams are almost useless as tutorials, and quite a bit of info missing for a beginner to tackle this.
It’s a good idea to show learners, but you need to put more effort in.
What display? CC or CA ?
The pinouts are specific to a module... what are they?
(I just noticed them, but can’t read them... please - a proper schematic.)
Maybe you can prep the content and update your post.
In general, Fritzy diagrams are only for the original person, they communicate very little to others.
Thanks for trying.
