Hi I am fairly new to Arduino code and have made a camera slider using the code from a YouTube project https://youtu.be/6Mp4lrz7Vc0?feature=shared It does everything I need it but I would like to increase the speed and have tried changing the values in the following section: -
(Speed_Delay = map(read_ADC, 0, 1023, 8000, 10); //value map for Microstep resolution Delay)
But it doesn't change. I have had a search around for how to do so and I think that I may not be able to without changing part of the code. If anyone could offer some help I would be very grateful.
If poss I would like to make the potentiometer have a wide range from very slow to high speed etc.
I am using a nema 17 Act Motor with an a4988 and a Nano board
Here is the code I am using:-
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
#define potentiometer A0 //10k Variable Resistor
#define bt_F A1 // Clockwise Button
#define bt_S A2 // Stop Button
#define bt_B A3 // Anticlockwise Button
#define dirPin 8 //8Pin of Arduino--Direction of stepper motor driver
#define stepPin 9 //9Pin of Arduino--Step of stepper motor driver
#define enPin 10 //10Pin of Arduino--Enabled of stepper motor driver
int read_ADC;
int Speed_LCD, Speed_Delay;
int Mode=1, flag=0;
void setup() { // put your setup code here, to run once
pinMode(potentiometer, INPUT); // declare potentiometer as input
pinMode(bt_F, INPUT_PULLUP); // declare bt_F as input
pinMode(bt_S, INPUT_PULLUP); // declare bt_S as input
pinMode(bt_B, INPUT_PULLUP); // declare bt_B as input
pinMode(dirPin, OUTPUT); // declare as output for Direction of stepper motor driver
pinMode(stepPin, OUTPUT); // declare as output for Step of stepper motor driver
pinMode(enPin, OUTPUT); // declare as output for Enabled of stepper motor driver
lcd.begin(16,2);
lcd.setCursor(0,0);
lcd.print(" WELCOME TO MY ");
lcd.setCursor(0,1);
lcd.print(" CAMERA SLIDER");
delay(2000); // Waiting for a while
lcd.clear();
read_ADC = analogRead(potentiometer); // read analogue to digital value 0 to 1023
Speed_LCD = map(read_ADC, 0, 1023, 0, 100); //value map to Display on the LCD
lcd.setCursor(0,0);
lcd.print(" Speed: ");
lcd.print(Speed_LCD);
lcd.print("% ");
if(digitalRead (bt_F) == 0){Mode = 2; digitalWrite(enPin, LOW);} //For Clockwise
if(digitalRead (bt_S) == 0){ //For Stop
if(flag==0){flag=1;
if(Mode>1)Mode=1;
else{Mode=!Mode;
if(Mode==0)digitalWrite(enPin, HIGH);
else digitalWrite(enPin, LOW);
delay(100);
}else{flag=0;}
if(digitalRead (bt_B) == 0){Mode = 3; digitalWrite(enPin, LOW);} //For Anticlockwise
lcd.setCursor(0,1);
if(Mode==0)lcd.print(" Free ");
else if(Mode==1)lcd.print(" Stop ");
else if(Mode==2)lcd.print(" > Right > ");
else if(Mode==3)lcd.print(" < Left < ");
if(Speed_LCD>0 && Mode>1){
if(Mode==2)digitalWrite(dirPin, LOW);// Stepper motor rotates CW (Clockwise)
else digitalWrite(dirPin, HIGH);// Stepper motor rotates CCW (Anticlockwise)
digitalWrite(stepPin, HIGH);
delayMicroseconds(Speed_Delay);
digitalWrite(stepPin, LOW);
