I'd like to hear some advice on choosing the right motor driver for my motors. My situation is the following:
I would like to drive
3x 24V 2.1A 30W DC motors
3x 12V 0.9A 11W DC motors
2x 12V 0.2A brake solenoids
All of these are part of a robot arm I'm working on.
Up until now I've been using multiple L298 dual H-Bridge drivers. But these are rather antique (as I've heard) and can't drive the 24V motors.
I control the drivers using an Arduino Mega, which I will perhaps switch out as well but that's for another thread.
The MAX14870 has a max. continous current value of 1.7A per channel without additional cooling. Could I reach the 2.1A I need by adding heat sinks and a fan? The datasheet wouldn't really tell me but I might not have understood it properly as english isn't my mother language.
The TB9051FTG has the needed characteristics but is twice as expensive. Should I use the MAX for the small motors and the brakes and the TB for the big motors?
I am also having problems with the motors giving off annoying sounds due to the PWM making them vibrate. I "fixed" it by increasing the frequency of the PWM-frequency above audible values. This in turn made the motors run alot worse. The power consumption decreased and so did torque and speed. Was this an issue of the L298 not being able to turn on and off fast enough or are the coils of the motors the troublemaker here?
I then put capacitors in parallel which made it a lot better but it's not perfect (still some sounds) and I would like to ditch them if they're not ultimately necessary.
Are there motor drivers that output a direct analog voltage? And are they affordable?
I know this is a lot to answer and I'm really grateful for all answers even if they cover only part of my questions.
I would choose a driver that can work at your required voltage and which will handle at least 20% more current than the stall current for your motor. The stall current can be 10 or 20 times the normal running current. If the driver is protected against overloads and short circuits you could probably get away with a lower max current, but I suggest at least 100% more than the normal running current. It is never a good idea to run electronic components at their limit.
Also choose a driver that uses MOSFETs as they are much more efficient.
Thank you for your lightning-quick responses! That already helped me a lot!
But I'm still a little confused here :
So let's pretend I have a driver that has an overload protection and can handle my voltage. The motor draws 2.1A max while unobstructedly turning. Which of the current ratings of the driver need to be 4.2A (2.1A + 100%) now? The current it can continuously handle, the peak current or the current that makes the overload protection trigger?
Smagel:
I would choose a driver with a continuous output of about twice the max running current. The stall current will be much higher and if the motor is stalled the driver would cut out and protect itself.
HOWEVER (life is never simple) if the motor must start with a heavy load it may draw close to the stall current for a brief period at startup and a driver that would cut out would cause problems.
Another thing to keep in mind is that many motors cannot withstand their stall current for more than few seconds so a driver that acts as a cut-out can also protect the motor.
It is really a bad idea and a waste of money to buy a motor driver that cannot easily handle the stall current. Fuses, not motor drivers, are the preferred way of protecting electronics and motors from overcurrent conditions.
It is also a really bad idea to run a motor at stall or near stall conditions, unless it is specifically designed for that.
Ok, I think I know now how to pick out the right driver. I'll learn about protecting my power supply and maybe put a fuse between motor and driver as well to prevent situations where the overcurrent protection indefinitely kicks in and resests.
