Good afternoon, I am building a line-following robot for a school project using PID and 8 QTR RC sensors that use the "qtrSensors.h" library.
The PID cannot make 90-degree turns very well, sometimes it even goes off the line. My idea would be to detect if more than 3 sensors on the respective side are detecting the line. If so, using the gyro sensor it will make a 90-degree turn. However, I do not know how to do the part where the detection of when the sensors are detecting the line on only one side to make the turn, using it as a conventional sensor without calculating the error to center the robot. Is it possible to do this?
//variaveis da biblioteca do sensor de refletancia
#include <QTRSensors.h>
QTRSensors qtr;
//variaveis de quantidade e de leitura dos sensores
const uint8_t sensores = 8;
uint16_t leituras[sensores];
//variaveis do PID
//ganhos proporcionais,integrais e derivados
float kp = 0.65;
float ki = 0;
float kd = 0.9;
uint8_t multiP = 1;
uint8_t multiI = 1;
uint8_t multiD = 1;
//variaveis de calculo de erro e PID
int erro;
int erroAnterior;
int P;
int I;
int D;
//variaveis usadas na multiplicacao dos valores
float Pvalue;
float Ivalue;
float Dvalue;
//variaveis dos motores
#include <AFMotor.h>
//define os motores
AF_DCMotor motorD(1);
AF_DCMotor motorE(2);
//variaveis de velocidade base,minima e maxima
int leftbasespeed = 100;
int rightbasespeed = 100;
int leftmaxspeed = 210;
int rightmaxspeed = 210;
int leftminspeed = 0;
int rightminspeed = 0;
// variaveis de cores rgb
// calibragem da cor branca e preta em aproximadamente 10 seg
void calibragem() {
for (uint16_t i = 0; i < 400; i++) {
qtr.calibrate(); {
//acoes executaveis ao iniciar
//define o tipo de sensor como digital (RC) e define as portas
qtr.setTypeRC();
qtr.setSensorPins((const uint8_t[]) {22, 24, 26, 28, 30, 32, 34, 36 }, sensores);
//ativa o monitor serial
calibragem();
/* leitura dos sensores tanto minima quanto maxima*/
void monitor() {
//mostragem minima
for (uint8_t i = 0; i < sensores; i++) {
Serial.print(qtr.calibrationOn.minimum[i]);
Serial.print(' ');
//mostragem maxima
Serial.print(qtr.calibrationOn.maximum[i]);
Serial.print(' ');
//calculo do pid
void PID() {
//calculo da posicao do robo com isso definindo o erro
uint16_t position = qtr.readLineBlack(leituras);
erro = 3500 - position;
//calculo do PID
int P = erro;
int I = I + erro;
int D = erro - erroAnterior;
//erro vira o erro anterior
erroAnterior = erro;
//calculo do PID
Pvalue = (kp / pow(10, multiP)) * P;
Ivalue = (ki / pow(10, multiI)) * I;
Dvalue = (kd / pow(10, multiD)) * D;
//calculo da velocidade dos motor
float motorspeed = Pvalue + Ivalue + Dvalue;
//separando a velocidade esquerda e direita
int leftspeed = leftbasespeed + motorspeed;
int rightspeed = rightbasespeed - motorspeed;
//limitando o minimo e maximo da velocidade
if (leftspeed > leftmaxspeed) {
leftspeed = leftmaxspeed;
if (rightspeed > rightmaxspeed) {
rightspeed = rightmaxspeed;
if (leftspeed < leftminspeed) {
leftspeed = leftminspeed;
if (rightspeed < rightminspeed) {
rightspeed = rightminspeed;
//executando o PID nos motores
motorD.run(FORWARD);
motorD.setSpeed(rightspeed);
motorE.run(FORWARD);
motorE.setSpeed(leftspeed);
//funcao de parada dos motores
void stop() {
//para os motores esquerdos e direitos
motorD.run(RELEASE);
motorE.run(RELEASE);
//funcao executada repetidamente
PID();
This is my code, if you know of anything that can be improved in addition to all this, it would be very helpful.
some parts of the code are in portuguese for example erro = error, erroAnterior = lastError, sensores = sensors, leituras = detection, calibragem = calibration
