Line tracking robot using QTR-8RC having trouble making 90 degree turns
Hello, everyone! I am trying to make a line following robot using the Pololu QTR-8RC sensor. The robot follows straight lines like a charm but struggles to make it through 90 degree turns.
I wrote some code of my own that checks the value of all the sensors against a pre-set threshold and then decides which direction to turn in. This is a breakout code that runs when all the sensors are on a white surface i.e. the robot has just missed the turn. The robot stops, reverses and rotates in the direction where the black line last was. This code somewhat works but not really well.
Using a Nano, L298N motor driver, 12V battery pack, EDVON kit motors and tires.
Here's my code:
#include <QTRSensors.h>
//variables for PID controller
#define Kp 0.07
#define Kd 0.235
int turn_reversing_power_duration = 170; //to slightly reverse the robot on a turn for better navigation
int reverse_speed = 130; //speed with which the car reverses
bool reverse_enable = true;
int rotation_duration = 90; //time to rotate the car to reallign itself on the line after a hard turn
int rotation_speed = 120;
int threshold = 1000; //to detect when the robot is off the black line
int test=1;  //to test the threshold setting
//float speed_reduction_factor = 0.9;
#define rightMaxSpeed 120
#define leftMaxSpeed 120
#define rightBaseSpeed 110
#define leftBaseSpeed 110
int turn_counter=0; //to slow down the car if it encounters consecutive turns
int turn_off_counter=0;
#define NUM_SENSORS 8
#define TIMEOUT 2500
#define EMITTER_PIN 7
#define rightMotor1 12
#define rightMotor2 11
#define rightMotorPWM 6
#define leftMotor1 10
#define leftMotor2 9
#define leftMotorPWM 5
int SumLeft = 0;
int SumRight = 0;
int SumDifference = 0;
int Last = 0;
int LastLeftval;
int LastRightval;
QTRSensorsRC qtrrc((unsigned char[]) {A7, A6, A5, A4, A3, A2, A1, A0}, NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
  pinMode(rightMotor1, OUTPUT);
  pinMode(rightMotor2, OUTPUT);
  pinMode(rightMotorPWM, OUTPUT);
  pinMode(leftMotor1, OUTPUT);
  pinMode(leftMotor2, OUTPUT);
  pinMode(leftMotorPWM, OUTPUT);
  int i;
  for (int i = 0; i < 100; i++) {
    qtrrc.calibrate();
    delay(20);
  wait();
  delay(2000);
int lastError = 0;
  unsigned int sensors[8];
  int position = qtrrc.readLine(sensors, QTR_EMITTERS_ON, 1);
   Serial.print("Line position: ");
  Serial.println(position);
  int error = position - 3500;
  SumRight = (sensors[0] + sensors[1] + sensors[2] + sensors[3]);
  SumLeft = (sensors[4] + sensors[5] + sensors[6] + sensors[7]);
  SumDifference = (SumLeft - SumRight);
  int motorSpeed = Kp * error + Kd * (error - lastError);
  lastError = error;
  int rightMotorSpeed = rightBaseSpeed + motorSpeed;
  int leftMotorSpeed = leftBaseSpeed - motorSpeed;
//  Serial.print(sensors[0], sensors[1], sensors[2], sensors[3], sensors[4], sensors[5], sensors[6], sensors[7])
    //code for sharp turn
  if (sensors[0] < threshold && sensors[1] < threshold && sensors[2] < threshold && sensors[3] < threshold && sensors[4] < threshold && sensors[5] < threshold && sensors[6] < threshold && sensors[7] < threshold and test==1 ){
    digitalWrite(13, HIGH);
    Serial.println("Off-line");
    if (LastLeftval < LastRightval) {
      analogWrite(leftMotorPWM,reverse_speed);
      analogWrite(rightMotorPWM,reverse_speed);
      if (reverse_enable ==true){
      digitalWrite(rightMotor1,LOW);
      digitalWrite(rightMotor2, HIGH);
      digitalWrite(leftMotor1, LOW);
      digitalWrite(leftMotor2,HIGH);
      delay(turn_reversing_power_duration);
      reverse_enable=false;
      analogWrite(leftMotorPWM,rotation_speed);
      analogWrite(rightMotorPWM,rotation_speed);
      digitalWrite(rightMotor1, HIGH);
      digitalWrite(rightMotor2, LOW);
      digitalWrite(leftMotor2, HIGH);
      delay(rotation_duration);
      digitalWrite(rightMotor1,HIGH);
      digitalWrite(leftMotor1, HIGH);
      digitalWrite(leftMotor2,LOW);
      delay(30);
      turn_counter=turn_counter+1;
//      digitalWrite(rightMotor1, LOW);
//      digitalWrite(leftMotor1, LOW);
    } else if (LastRightval < LastLeftval) {
      analogWrite(leftMotorPWM, reverse_speed);
      if (reverse_enable==true){
      reverse_enable =false;
      digitalWrite(leftMotor2, LOW);
      delay(30);
    if (rightMotorSpeed > rightMaxSpeed) rightMotorSpeed = rightMaxSpeed;
    if (leftMotorSpeed > leftMaxSpeed) leftMotorSpeed = leftMaxSpeed;
    if (rightMotorSpeed < 0) rightMotorSpeed = 0;
    if (leftMotorSpeed < 0) leftMotorSpeed = 0;
    //to slow down the car when exiting a turn
    if (turn_counter>0){
    analogWrite(rightMotorPWM, 60);
    analogWrite(leftMotorPWM, 60);
//    delay(100);
    else{
    analogWrite(rightMotorPWM, rightMotorSpeed);
    analogWrite(leftMotorPWM, leftMotorSpeed);
    reverse_enable=true;
  turn_off_counter = turn_off_counter+1;
  LastLeftval = SumLeft;
  LastRightval = SumRight;
  if (turn_off_counter>=50){
    turn_counter=0;
void wait() {
What changes can I make to make this work?
Any help would be appreciated.
You will need to explain the problems in detail, because no one else has your hardware to test. See the "How to get the best out of this forum" post.
How many wheels (3? 2? 4?) Which direction is the struggle turn (left? right? both?). Which motors are turning (left, right)? Which direction are the turning motors turning (fwd, rev)? Which motors are not moving (pivot points)? What is your favorite color? If there is a pivot point, is it on the inside of the turn (outboard wheels moving forward) or the outside of the turn (inboard wheels moving reverse)? Et c.
Apologies for not. Being specific enough.
I have 2 wheels and one caster wheel. 2 6V DC motors control the wheels. The motors turn so as to turn the car in the right direction most of the time but mot of the time, the car overshoots. I tried correcting this by altering the values of rotation duration (duration for which the car rotates in a certain direction) and with what speed it rotates. The pivot point is on the inside.
Maybe the pivot wheel is slipping? Have you tried other pivot points?
