Going bonkers on a level-shifter
I have a bunch of 4-way level shifters. These, to be precise: Amazon.com: HUAREW IIC I2C Logic Level Converter Bi-Directional Module with 4 Way Channels 5V to 3V Shifter Compatible with Arduino(12 pcs) : Electronics
If I test this part stand-alone, in a circuit where there’s nothing but a bench power supply providing 5V and then a (separate) regulator stepping that down to 3.3V, and then I tie the LV side of a channel to either +3.3V or GND, I see the expected output of either 5V or 0V on the HV side. OK, seems great.
However, when I try to actually use this part, and I drive the LV input from a GPIO pin on my RP2040-Zero, alternating between high and low every 3 seconds, I can see, with a volt meter on the LV side, the input going from +3.3V to 0V and back, but the HV output side stays high (+5V) all the time.
What could cause this? I’ve tried it with pull-up resistors (silly, since the part appears to have them included), pull-downs, etc. I just cannot get this thing to function in an actual circuit. What could I possibly be doing wrong? Ideas?
Regards,
Ian
Need a drawing of your circuit
This sketch
byte ledPin = 15;
void setup(){
   pinMode(ledPin, OUTPUT);
void loop(){
   digitalWrite(ledPin, !digitalRead(ledPin));
with this circuit
results in a blinking LED when power is applied.
Measuring the voltage at HV1 shows alternating 0v/~3V with the LED in circuit. With the LED removed, 0V/5V is observed.
Post a schematic of the "actual circuit", including all power supply and ground connections. Hand drawn is fine.
Yep that isn’t a circuit drawing , how it powered ?? Where are you measuring voltages??
Are grounds common between hv and lv ?
What are the output voltages from the micro board in both cases ? Can the 5v pin supply power ?
Are the power connections/0v continuous across the top and bottom ?
“ The Arduino RP2040 Connect operates at 3.3 V, and has the 5V pin (VUSB) disabled by default. This is a safety precaution, as connecting higher voltage signals to the board can damage the hardware.”
The 5V pin will be enabled if the pads marked VUSB are shorted, by soldering them.
Your picture is useless, it indicates how you might put the wires but there is no collation to the actual circuit. Your breadboard could be the cause of your problem, maybe the missing HV connections, or many other things. You will get a much more accurate answer when the annotated schematic is posted.
Here’s the schematic, although please understand: I have disconnected the speed controller, and I’ve disconnected the motor driver. I’m literally just working with 2 buck converters, stepping down from 36VDC to 5.0V and 3.3V, the RP2040-Zero, and the level shifter chip. Nothing else. I’ve removed every variable I can think of.
Nothing obviously wrong with the schematic.
Use your multimeter to check continuity of all connections (especially GND) and that voltages everywhere are what you expect.
You could have a defective level converter. Try another one.
I generally avoid mass sales of junk on Amazon, eBay, Alibaba and the like. The money saved is rarely worth the headaches gained.
  • Please give us a link to your motor driver module.
  • The controller would best drive the motor driver with BJTs or logic level MOSFETs.
What (and how) is connected to the left side of J1?
Interesting data point:
I’ve tried three different parts of those 12 pin, 4-way level shifters, and none of them worked, and all failed in the same way. Then, on a lark, I tried a TXS0108E that I had on hand… and it worked perfectly right out of the gate. I have another 5 of the 4 channel shifters, but… I’m not sure it’s worth my time. I generally expect that parts mostly work.
I still struggle to understand why those smaller level shifters are failing, especially considering that they’re made of discrete components, and TXS0108E is an IC, but that’s what I’m seeing.
I’m more than a little pissy about this because I have a PCB being fabricated based on the 4 channel, 12-pin parts, but at least I no longer feel like I’m ‘missing something’, since other level shifters are working as expected.
Maybe I just got a bum batch of parts, but what do I know?
-Ian
Nothing. As mentioned, everything else has been disconnected.
The motor driver is this: https://www.ebay.com/itm/335249512933 or https://en.cwmotor.cn/product/84.html
But again, it’s not connected. I’m just looking at the volt meter and the oscilloscope.
-Ian
This is not a good assumption for unknown sellers on Amazon, eBay, Alibaba and the like.
Good luck with your project.
The "LDO" stuff is BS.
Do your items look EXACTLY like these, having no solder? (That would guarantee their non-op.)
If you soldered them, perhaps you could demo same.
  • Not sure why there’s a need for a bidirectional converter.
  • Use a BJT. Controller o/p goes to a base resistor, emitter to GND.
    Collector to motor driver logic + supply through a pull-up resistor.
  • inversion can be handled in software.
  • Alternatively, a voltage comparator can be used.
  • Read the Control Signal Connector Interface section.
Yeah, I soldered the pins onto the board myself, and I’m quite confident in my soldering skills (been doing it every few weeks for 35+ years, without issue).
Those modules are designed for I2C level shifting.
The can only pull-down. Pull up is always weak, through the 10k resistors.
The LED in the test of post#3 should have been between HV1 and 5volt, not ground.
The first opto diagram in post#16 therefore won't work, the last one will.
Leo..
You can level logic on 1 line with a diode and a pullup, I bought the cheap 74HC405 in bulk… 16 pins for 6 channels of 5 to 3. I think I got 3 or 4 per $1 pre-COVID.
There is no need to raise 3.3V signals to 5V since 3V is enough to be HIGH to 5V pins.
OP didn't tell us yet why the need for that.
Most motor controllers are happy with 3.3volt-logic.
Leo..
Not the sort of advert to fill you with confidence.
"provide no more than 150-mA"
