Hi there, here another newbe.
Can someone please help me with my project?
Two weeks ago I had an idea about a beating LED heart to the beat of the music.
But I couldn't find anything so decided to make it myself. So I googled and bought an Arduino starter kit, but now I'm stuck.
I've now got the matrix working, managed to animate a heart and I can also sort of set the brightness with a potentiometer.
However, I can't manage to code the sound sensor to move to the beat.
And I have not yet figured out which portable power supply I need in combination with which circuit (enough power supply 256 LEDs but not too much for Arduino nano). I've allready blew up a 16x16 LED matrix ![]()
Is there someone who can help me with this?
Rgds, Cris
hereby the code:
/* Arduino 256 RGB LEDs Matrix Animation Frame
* Using WS2812 LED Strips
Created by Yvan / https://Brainy-Bits.com
This code is in the public domain...
You can: copy it, use it, modify it, share it or just plain ignore it!
Thx!
#include <avr/pgmspace.h> // Needed to store stuff in Flash using PROGMEM
#include "FastLED.h" // Fastled library to control the LEDs
// How many leds are connected?
#define NUM_LEDS 256
// Define the Data Pin
#define DATA_PIN 3 // Connected to the data pin of the first LED strip
// Define the array of leds
CRGB leds[NUM_LEDS];
#define MAX_BRIGHTNESS 164 // Thats full on, watch the power!
#define MIN_BRIGHTNESS 10 // set to a minimum of 25%
const int brightnessInPin = A0; // The Analog input pin that the brightness control potentiometer is attached to.
int micPin = A1;
int sensorValue = 0;
// Create the array of retro arcade characters and store it in Flash memory
const long HeartBeat01[] PROGMEM =
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
const long HeartBeat02[] PROGMEM =
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000,
0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
const long HeartBeat03[] PROGMEM =
0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff000000,
0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000,
0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000, 0xff000000,
0xff000000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000,
0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff0000, 0xff000000,
Serial.begin (9600);
FastLED.addLeds<NEOPIXEL,DATA_PIN>(leds, NUM_LEDS); // Init of the Fastled library
FastLED.setBrightness(MAX_BRIGHTNESS);
// read the analog brightness value:
//int brightValue = analogRead(brightnessInPin);
// map it to the range of the FastLED brightness:
int mappedValue = map(analogRead(brightnessInPin), 0, 1023, 0, 255);
FastLED.setBrightness(constrain(mappedValue, MIN_BRIGHTNESS, MAX_BRIGHTNESS));
sensorValue = analogRead (micPin);
Serial.println (sensorValue, DEC);
delay (1000);
// Put HeartBeat01 delay750
for(int passtime = 0; passtime < 1; passtime++) { // Display it 1 time
FastLED.clear();
for(int i = 0; i < NUM_LEDS; i++) {
leds[i] = pgm_read_dword(&(HeartBeat01[i])); // Read array from Flash
FastLED.show();
delay(750);
// Put HeartBeat02 delay 50
FastLED.clear();
leds[i] = pgm_read_dword(&(HeartBeat02[i]));
FastLED.show();
delay(25);
// Put HeartBeat03 delay 50
FastLED.clear();
leds[i] = pgm_read_dword(&(HeartBeat03[i]));
FastLED.show();
delay(25);
FastLED.clear();
leds[i] = pgm_read_dword(&(HeartBeat02[i])); // Read array from Flash
FastLED.show();
delay(25);
// Put HeartBeat01 delay 133
FastLED.clear();
FastLED.show();
delay(67);
// Put HeartBeat02 delay 60
FastLED.clear();
FastLED.show();
delay(25);
FastLED.clear();
FastLED.show();
delay(25);
FastLED.clear();
FastLED.show();
delay(25);
