"Hello World" on analog pins "SOLVED"
I am trying to get my 2x16 display to work on analog pins A0, A1,A2, A3, A5, and D5 with my old Nano.
It is a small part of a larger project that requires these pins to be used as the digital pins are in use.
I have run Hello World just fine using the digital pins but can't seem to get anything from the analog pins.
Here is the original code to the project and schematic
 * Portable Function Generator on Arduino v1.0
 * Designed by Faransky, 2018
 * Custom libraries are designed by:
 *    LiguidCrystal - Core Arduino library
 *    SPI - Core Arduino library
 *    Arduino pin change block - Generic example on the https://playground.arduino.cc/
 *    MD_AD9833 Library by MajCDesigns https://github.com/MajcDesigns/
// include the library code:
#include <LiquidCrystal.h>
#include <SPI.h>
#include <MD_AD9833.h>
#include "pins_arduino.h"
/* Digital potentiometer constants */
#define DP_nINC 4 // D4
#define DP_UnD  3 // D3
#define DP_nCS  2 // D2
/* LCD Constants */
#define LCD_D7 14 // A0
#define LCD_D6 15 // A1
#define LCD_D5 16 // A2
#define LCD_D4 17 // A3
#define LCD_E  19 // A5
#define LCD_RS 5 // D5
/* Function generator constants */
#define DATA 11 // D11
#define CLK 13 // D13
#define FSYNC 10 // D10
/* Other pin definition constants */
#define VBAT 21 // A7
#define CAP_ON 18 // A4
#define CATHODE_PWM 9 // D9
/* Boolean Constants */
#define OFF false
#define ON true
/* Encoder constants */
#define ENC_A 8   // D8
#define ENC_B 7   // D7
#define ENC_SW 6  // D6
/* Encoder States */
#define UP 1
#define DOWN -1
#define SAME 0
/* Sequential state machine constants */
enum OutputConstants { NOFF = 1, SINE, TRIG, SQUARE };
enum States { StateOut = 1, StateAmplitude, Coupling, StateFreqHz, StateFreqKhz, StateFreqMhz, Brightness};
/* Custom LCD battery characters */
byte Bat0[8] = {0b01110, 0b11011, 0b10001, 0b10001, 0b10001, 0b10001, 0b10001, 0b11111};
byte Bat1[8] = {0b01110, 0b11011, 0b10001, 0b10001, 0b10001, 0b11111, 0b11111, 0b11111};
byte Bat2[8] = {0b01110, 0b11011, 0b10001, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111};
byte Bat3[8] = {0b01110, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111};
/* AD9833 & LCD Library objects definition */
MD_AD9833  AD(FSYNC);
MD_AD9833::channel_t chan;
MD_AD9833::mode_t mode;
LiquidCrystal lcd(LCD_RS, LCD_E, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
/* Global state machine in-used variables */
unsigned char MenuState = StateOut;   // Initial state
volatile uint8_t OutType = NOFF;      // Output waveform type
volatile uint8_t DigiPotState = 0;    // Digital potentiometer wiper state
volatile bool CouplingOn = true;      // AC or DC coupling state
volatile uint8_t BrightnessState = 0; // LCD Backlight brightness state
/* Encoder pins state */
volatile bool encoder_A = false;
volatile bool encoder_B = false;
volatile bool encoder_A_prev = false;
/* Frequency states */
volatile uint32_t FreqHz = 0;
volatile uint32_t FreqKhz = 0;
volatile uint32_t FreqMhz = 0;
/* Function prototypes */
volatile uint8_t *port_to_pcmask[] = { &PCMSK0, &PCMSK1,&PCMSK2 };
static int PCintMode[24];
typedef void (*voidFuncPtr)(void);
volatile static voidFuncPtr PCintFunc[24] = { NULL };
volatile static uint8_t PCintLast[3];
void EnableInterrupts();
void DisableInterrupts();
void InitEncoder();
void InitOther();
void InitDigipot();
void CreateLcdChars();
byte ProcessBatteryVoltage();
void SetLcdBrightness(int brightness);
void PotDown();
void PotUp();
void InitPotState();
void InitDevice();
void SetADFrequency();
void SetADOutput();
void SetADOutType();
void BrightnessUp();
void BrightnessDown();
volatile int GetEncoderPos();
void EncoderPositionChanged();
void MainMenu();
/* Pin-change interrupts block */
void PCattachInterrupt(uint8_t pin, void (*userFunc)(void), int mode)
  uint8_t bit = digitalPinToBitMask(pin);
  uint8_t port = digitalPinToPort(pin);
  uint8_t slot;
  volatile uint8_t *pcmask;
  // map pin to PCIR register
  if (port == NOT_A_PORT) return;
  else {
    port -= 2;
    pcmask = port_to_pcmask[port];
  if (port == 1) slot = port * 8 + (pin - 14);
  else slot = port * 8 + (pin % 8);
  PCintMode[slot] = mode;
  PCintFunc[slot] = userFunc;
  *pcmask |= bit;
  PCICR |= 0x01 << port;
void PCdetachInterrupt(uint8_t pin) {
  else {
    port -= 2;
  *pcmask &= ~bit;
  if (*pcmask == 0)  PCICR &= ~(0x01 << port);
static void PCint(uint8_t port) {
  uint8_t bit;
  uint8_t curr;
  uint8_t mask;
  uint8_t pin;
  curr = *portInputRegister(port+2);
  mask = curr ^ PCintLast[port];
  PCintLast[port] = curr;
  if ((mask &= *port_to_pcmask[port]) == 0) return;
  for (uint8_t i=0; i < 8; i++) {
    bit = 0x01 << i;
    if (bit & mask) {
      pin = port * 8 + i;
      // Trigger interrupt if mode is CHANGE, or if mode is RISING and
      // the bit is currently high, or if mode is FALLING and bit is low.
      if ((PCintMode[pin] == CHANGE
          || ((PCintMode[pin] == RISING) && (curr & bit))
          || ((PCintMode[pin] == FALLING) && !(curr & bit)))
          && (PCintFunc[pin] != NULL)) {
        PCintFunc[pin]();
/* Interrupt masking functions */
SIGNAL(PCINT0_vect) { PCint(0); }
SIGNAL(PCINT1_vect) { PCint(1); }
SIGNAL(PCINT2_vect) { PCint(2); }
/* End of pin-change interrupts block */
/* Enable/disable encoder pin interrupts */
  PCattachInterrupt(ENC_A, EncoderPositionChanged, CHANGE);
  PCattachInterrupt(ENC_B, EncoderPositionChanged, CHANGE);
  PCdetachInterrupt(ENC_A);
  PCdetachInterrupt(ENC_B);
void InitEncoder()
  pinMode(ENC_A, INPUT);
  pinMode(ENC_B, INPUT);
  pinMode(ENC_SW, INPUT);
void InitOther()
  pinMode(VBAT, INPUT_PULLUP);
  pinMode(CAP_ON, OUTPUT);
  pinMode(CATHODE_PWM, OUTPUT);
void InitDigipot()
  pinMode(DP_nINC, OUTPUT);
  pinMode(DP_UnD, OUTPUT);
  pinMode(DP_nCS, OUTPUT);
  lcd.createChar(1, Bat0);
  lcd.createChar(2, Bat1);
  lcd.createChar(3, Bat2);
  lcd.createChar(4, Bat3);
/* Process Li-ion battery voltage state and return appropriate character */
  int BatVoltage  = analogRead(VBAT);
  //Serial.println(BatVoltage);
  if (BatVoltage >= 950 && BatVoltage <= 1023) return (byte)4;
  else if (BatVoltage >= 900 && BatVoltage < 950) return (byte)3;
  else if (BatVoltage >= 850 && BatVoltage < 900) return (byte)2;
  else {
    //Serial.println("Encoder came here");
    return (byte)1;
  analogWrite(CATHODE_PWM, brightness);
void PotDown()
  for (uint8_t i = 0; i < 4; i++) {
  digitalWrite(DP_UnD, LOW);
  digitalWrite(DP_nINC, LOW);
  delayMicroseconds(100);
  digitalWrite(DP_nINC, HIGH);
  if (DigiPotState <= 0) DigiPotState = 0;
  else DigiPotState--;
void PotUp()
  digitalWrite(DP_UnD, HIGH);
  if (DigiPotState >= 255) DigiPotState = 255;
  else DigiPotState++;
void InitPotState()
{ for (digitalWrite(DP_nCS, LOW); {}
 _delay_ms(10);
  for (uint8_t i = 0; i < 255; i++) PotDown();
void InitDevice()
  InitEncoder();
  InitDigipot();
  InitPotState();
  InitOther();
  Serial.begin(57600);
  Serial.println("Serial logger is enabled");
  lcd.begin(16, 2);
  AD.begin();
  uint32_t u1 = FreqHz + (FreqKhz * 1000) + (FreqMhz * 1000000);
  chan = MD_AD9833::CHAN_0;
  AD.setFrequency(chan, u1);
void SetADOutput()
  AD.setActiveFrequency(chan);
void SetADOutType()
switch (OutType)
      case NOFF: mode = MD_AD9833::MODE_OFF;    break;
      case SINE: mode = MD_AD9833::MODE_SINE;   break;
      case TRIG: mode = MD_AD9833::MODE_TRIANGLE;  break;
      case SQUARE: mode = MD_AD9833::MODE_SQUARE1;  break;
      default: break;
AD.setMode(mode);
  InitDevice();
  CreateLcdChars();
  SetADOutput();
  pinMode(A4,OUTPUT);
  digitalWrite(A4,HIGH);
  AD.setMode(mode);
  SetADFrequency();
  BrightnessState = 127;
  SetLcdBrightness(BrightnessState);
void BrightnessUp() {
  if (BrightnessState >= 250) BrightnessState = 255;
  else BrightnessState += 4;
void BrightnessDown() {
  if (BrightnessState <= 5) BrightnessState = 0;
  else BrightnessState -= 4;
    volatile int RetVal = 0;
    encoder_A = digitalRead(ENC_A);
    encoder_B = digitalRead(ENC_B);
    delay(10);
    if((!encoder_A) && (encoder_A_prev)){
      if(encoder_B) RetVal = 1;
      else RetVal = -1;
    else RetVal = 0;
    encoder_A_prev = encoder_A;     // Store value of A for next time
    return RetVal;
   switch(MenuState) {
    case StateFreqHz:
      switch(GetEncoderPos()) {
            case UP:
              if (FreqHz >= 900) FreqHz = 900;
              else FreqHz += 10;
            case DOWN:
               if (FreqHz < 10) FreqHz = 0;
               else FreqHz-= 10;
            default: break;
          SetADFrequency();
  case StateFreqKhz:
            case UP:
              if (FreqKhz >= 900) FreqKhz = 900;
              else FreqKhz += 1;
            case DOWN:
               if (FreqKhz <= 10) FreqKhz = 0;
               else FreqKhz -= 1;
            default: break;
          SetADFrequency();
  case StateFreqMhz:
            case UP:
              if (FreqMhz >= 10) FreqMhz = 10;
              else FreqMhz++;
            case DOWN:
               if (FreqMhz <= 0) FreqMhz = 0;
               else FreqMhz--;
            default: break;
          SetADFrequency();
  case StateAmplitude:
            case UP: PotUp(); break;
            case DOWN: PotDown(); break;
            default: break;
  case StateOut:
            case UP:
              if (OutType >= SQUARE) OutType = SQUARE;
              else OutType++;
            case DOWN:
              if (OutType <= NOFF) OutType = NOFF;
              else OutType--;
            default: break;
          SetADOutType();
   case Coupling:
        case UP: CouplingOn = true; break;
        case DOWN: CouplingOn = false; break;
        default: break;
      digitalWrite(CAP_ON,CouplingOn);
    case Brightness:
            case UP: BrightnessUp(); break;
            case DOWN: BrightnessDown(); break;
            default: break;
  default: break;
void MainMenu()
  EnableInterrupts();
  bool OutConfirm = false;
  while(!OutConfirm)
    switch(MenuState)
      case StateFreqHz:
        lcd.setCursor(0,0);
        lcd.print("<Frequency: Hz >");
        lcd.setCursor(0,1);
        lcd.print("<Val:");
        lcd.setCursor(5,1);
        lcd.print(FreqHz);
        if (FreqHz <= 9) {
          lcd.setCursor(6,1);
          lcd.print("  ");
        else if (FreqHz > 9 && FreqHz <= 99) {
          lcd.setCursor(7,1);
          lcd.print(" ");
        lcd.setCursor(8,1);
        lcd.print("[Hz]   >");
          if (!digitalRead(ENC_SW)) {
            while(!digitalRead(ENC_SW));
            MenuState = StateFreqKhz;
      case StateFreqKhz:
        lcd.setCursor(0,0);
        lcd.print("<Frequency:KHz >");
        lcd.setCursor(0,1);
        lcd.print("<Val:");
        lcd.setCursor(5,1);
        lcd.print(FreqKhz);
        if (FreqKhz <= 9) {
          lcd.setCursor(6,1);
          lcd.print("  ");
        else if (FreqKhz > 9 && FreqKhz <= 99) {
          lcd.setCursor(7,1);
          lcd.print(" ");
        lcd.setCursor(8,1);
        lcd.print("[KHz]  >");
            MenuState = StateFreqMhz;
      case StateFreqMhz:
        lcd.setCursor(0,0);
        lcd.print("<Frequency:MHz >");
        lcd.setCursor(0,1);
        lcd.print("<Val:");
        lcd.setCursor(5,1);
        lcd.print(FreqMhz);
        if (FreqMhz <= 9) {
          lcd.setCursor(6,1);
          lcd.print("  ");
        else if (FreqMhz > 9 && FreqMhz <= 99) {
          lcd.setCursor(7,1);
          lcd.print(" ");
        lcd.setCursor(8,1);
        lcd.print("[MHz]  >");
            MenuState = Brightness;
        lcd.setCursor(0,0);
        lcd.print("<Amplitude in %>");
        lcd.setCursor(0,1);
        lcd.print("<Value:");
        lcd.setCursor(7,1);
        lcd.print((DigiPotState*100)/255);
        if ((DigiPotState*100)/255 <= 9) {
          lcd.setCursor(8,1);
          lcd.print("  ");
        else if ((DigiPotState*100)/255 > 9 && (DigiPotState*100)/255 < 100) {
          lcd.setCursor(9,1);
          lcd.print(" ");
        lcd.setCursor(10,1);
        lcd.print(" [%] >");
            MenuState = Coupling;
      case StateOut:
        lcd.setCursor(0,0);
        lcd.print("<   Out Type   >");
        lcd.setCursor(0,1);
        lcd.print("<Out:");
        lcd.setCursor(5,1);
        switch (OutType)
          case NOFF:   lcd.print("Off       >"); break;
          case SINE:   lcd.print("Sine      >"); break;
          case TRIG:   lcd.print("Triangle  >"); break;
          case SQUARE: lcd.print("Square    >"); break;
          default: break;
            MenuState = StateAmplitude;
     case Coupling:
        lcd.setCursor(0,0);
        lcd.print("< Out Coupling >");
        lcd.setCursor(0,1);
        lcd.print("<Type:");
        lcd.setCursor(6,1);
        switch (CouplingOn)
          case true:   lcd.print(" [DC]    >"); break;
          case false:   lcd.print(" [AC]    >"); break;
          default: break;
            MenuState = StateFreqHz;
case Brightness:
        lcd.setCursor(0,0);
        lcd.print("<  Brightness  >");
        lcd.setCursor(0,1);
        lcd.setCursor(7,1);
        lcd.print((BrightnessState*100)/255);
        if ((BrightnessState*100)/255 <= 9) {
          lcd.setCursor(8,1);
          lcd.print("  ");
        else if ((BrightnessState*100)/255 > 9 && (BrightnessState*100)/255 < 100) {
          lcd.setCursor(9,1);
          lcd.print(" ");
            OutConfirm = true;
      delay(50);
  /* Battery Character */
  lcd.setCursor(15, 0);
  lcd.write(ProcessBatteryVoltage());
  /* Out State */
  lcd.setCursor(0,0);
  lcd.print("<Output:");
  lcd.setCursor(8,0);
  if (OutType != NOFF) lcd.print("ON ");
  else lcd.print("OFF");
  lcd.setCursor(11,0);
  lcd.print(" > ");
  /* Output Type */
  lcd.setCursor(0,1);
  lcd.print("<Y:");
  lcd.setCursor(3,1);
  switch(OutType) {
    case NOFF:    lcd.print("OFF "); break;
    case SINE:    lcd.print("SIN "); break;
    case TRIG:    lcd.print("TRN "); break;
    case SQUARE:  lcd.print("SQR "); break;
    default: break;
  /* Amplitude */
  lcd.setCursor(7,1);
  lcd.print("[A]:");
          lcd.setCursor(12,1);
          lcd.print("  ");
          lcd.setCursor(13,1);
          lcd.print(" ");
        lcd.setCursor(14,1);
        lcd.print("%>");
    MainMenu();
  delay(50);
I have modified "Hello World" to the following 2 examples but neither of them work.
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * LCD VSS pin to ground
 * LCD VCC pin to 5V
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 modified 7 Nov 2016
 by Arturo Guadalupi
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystalHelloWorld
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = D5, en = A5, d4 = A3, d5 = A2, d6 = A1, d7 = A0;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
And
 and shows the time.
  The circuit:
 * LCD VCC pin to 5V
 * 10K resistor:
 by David A. Mellis
 by Tom Igoe
 by Tom Igoe
 modified 7 Nov 2016
 by Arturo Guadalupi
const int rs = 5, en = 19, d4 = 17, d5 = 16, d6 = 15, d7 = 14;
  lcd.begin(16, 2);
I can't code to save my soul so I rely on the graciousness of others to help me with my projects.
I did post this a different way in another area but it went stagnant quickly and I thought I should just work on the display part of the project to start. If the display won't work I can't tell if I made other mistakes.
I appreciate any insight and time spent assisting me.
Arduino function gener.pdf (250.7 KB)
After the helpful tips given here, I decided to go back and check all my wiring for the umpteenth time. Finding it all good I decided to check all my solder joints. I didn't have any bridges and everything looked good. I toned out all the connections from the Nano to the display and found no continuity between pin 14(A0) and the display. I then inspected the pins on my Nano and found a cold solder joint on, yep, pin 14 (A0). A little more flux and heat to reflow, upload the sketch and we're off to the races. I'm usually a pretty good solderer, I guess I got a little too excited and rushed a few of the joints. I ended up fixing 5 or so that looked suspect.
You aren't using any other hardware that is on the I2C bus?
As A4 and A5 double up as the SDA and SCL pins.
A schematic would be good at this point.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Link please?
Does the LCD work using the default pins in the library example? There is no reason it should not work using the analog pins, as long as your wiring is correct. Do not use A6 or A7, those will only work as analog inputs.
If it works with the digital pins, try replacing the pins with the analog pins, one at a time, testing each time. With an old nano, it is possible you damaged an analog pin sometime in the past and forgot about it.
The nano was sealed in an electrostatic bag never used. It works fine on the digital pins.
I don't believe so. Unless there's another way besides A4 and A5. I got so frustrated a while back because I couldn't code I put everything away for a while. Now the little I did know I no longer know. got a little ahead of myself and have edited to include the schematic I'm trying to follow. Thanks.
I'm guessing you mean to the LCD. I got it years ago but this one seems to be the same.
HiLetgo 2pcs HD44780 1602 LCD Display Module DC 5V 16x2 Character LCM Blue Blacklight New Amazon.com
I love this guy he's helped me a lot.
Is the code compiling?
There is no D5 symbol in nano. Arduino normally uses naked constants for the arduino pin numbers. The ESP boards created Dn symbols to do their internal mapping to GPIO bit numbers, but on a nano you should be using naked constants for your arduino pin numbers.
--- bill
Yes it compiles and uploads. I've even done A0,A1,A2,A3,A5,and 5.
The original project code compiles and uploads as well.
Naked constants?
@Travalon there is really no D5 for the Arduino Nano, bperrybap noticed a serious problem that you need to fix.
This sketch:
  Serial.println(D5);
void loop() {}
does not compile for a Arduino Nano (the old/original Nano with ATmega328P microcontroller). It gives this compiler error:
...sketch.ino: In function 'void setup()':
...sketch.ino:6:18: error: 'D5' was not declared in this scope
   Serial.println(D5);
Perhaps one of the libraries has a "D5", I did not check that.
Where is LCD_V0 going to ?
Have you tried what I suggested?
Set the LCD up with the Nano on the digital pins, so that the sketch is working.
Change the wiring from one of the digital pins to an analog pin, modify the sketch to use that pin, and upload the sketch to see if it still works.
Repeat for one connection at a time, until it stops working, then figure out why it stops at that specific point.
Oh... I misunderstood you. No I have not. I'm working nights so I'll try tonight and report back. Thank you!
5 (a naked constant) is not the same as D5 (which is a symbol)
You were using D5 in the example HelloWorld sketch you posted.
I have no clue where D5 could be defined/declared but it is not part of the variant file for nano.
You need to use naked constants for Arduino pin numbers on nano to ensure you are getting the Arduino pin you want.
--- bill
Gotcha. I actually tried both because of things I found in my searching.
Well I can't believe i brain farted basic troubleshooting. I did as you said and it turns out A0/Pin14 didn't want to work. Digital 12 was open so i mapped it there and "Hello World" worked like a charm. So i rewired the display back into my project, modified the original code and uploaded it. IT WORKED!!!!! Kinda. The display is working and responding to the digital pot but everything is in Klingon. It'd be nice to get it in English as I don't have time to learn a new language. Thank you for reminding me of basic systematic troubleshooting.
