Help me fix my engine controller/h bridge
so my engine controller has 2-p-mosfet and 2-n-mosfet
the p-mosfet and the n-mosfet is shorting
bdw the point of the Circuit is to to give + -5 volts to a output and get controlled by +-+5v on gate
GATE IS +V5
here's my schematic
1809192214_Infineon-Technologies-IRF9530NPBF_C2574.pdf (225.9 KB)
1809050204_Infineon-Technologies-IRF3710PBF_C2562.pdf (218.9 KB)
Your voltage labels are confusing. What's Vcc?
IRF MOSFETs can not be controlled by 5V.
What are the GATE voltages, with regards to which supply voltage?
OK
I fixed it
VCC is -7V
Which two voltage levels come from GATE?
Where are data sheets for the MOSFETs?
the Gate is negative by default
which means output is pin1+ pin2+
but when Gate (pin1 or 2) is high (+5)
output is pin1+ pin2-
