If the two sensors detect specific thing based on its use, the buzzer should activate, if one sensor detect, the buzzer should not activate. Can you help me?
This is my code
#include<SoftwareSerial.h>
#include <DHT.h>
#include <Wire.h>
#include <LCD.h>
#define DHTPIN 4 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
//ALWAYS USE THIS WITH LCD I2C and Addres 0x27
#define I2C_ADDR 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
//Variables
int chk;
float hum; //Stores humidity value
float temp; //Stores temperature value
int sensorPin = A0; // select the input pin for the LDR
int sensorValue = 0; // variable to store the value coming from the sensor
int led = 9; // Output pin for LED
int buzzer = 13; // Output pin for Buzzer
int redLed = 12;
int greenLed = 11;
int smokeA0 = A5;
// Your threshold value
int sensorThres = 250;
// declare the ledPin and buzzer as an OUTPUT:
pinMode(led, OUTPUT);
pinMode(buzzer,OUTPUT);
dht.begin();
lcd.begin(16,2);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(smokeA0, INPUT);
Serial.println("Investigatory Project 2018 F.L.A.M.E.");
Serial.println("[FLAME SENSOR]");
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
if (sensorValue < 100)
Serial.println("Fire Detected");
Serial.println("LED on");
digitalWrite(led,HIGH);
digitalWrite(led,LOW);
delay(sensorValue);
//Read data and store it to variables hum and temp
hum = dht.readHumidity();
temp = dht.readTemperature();
//Print temp and humidity values to serial monitor
Serial.print("Humidity: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.println(" Celsius");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Temp: ");
lcd.print(temp);
lcd.print(" ");
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Hum: ");
lcd.print(hum);
lcd.print(" %");
delay(500); //Delay 2 sec.
int analogSensor = analogRead(smokeA0);
Serial.print("[GAS LEVEL]");
Serial.println(analogSensor);
// Checks if it has reached the threshold value
if (analogSensor > sensorThres)
digitalWrite(redLed, HIGH);
digitalWrite(greenLed, LOW);
tone(buzzer, 1000, 2000);
digitalWrite(redLed, LOW);
digitalWrite(greenLed, HIGH);
noTone(buzzer);
delay(100);
