i need help, i want to make a p10 hub with parallel connection without zigzagging cables. Is there a way to do that?
I want this connection to be changed so that it doesn't have to be in a zig zag position so later panel 6 is connected to panel 3
I was in doubt.
What are you talking about?
Sorry I'm a new user here. I want to make a led matrix, but I want the connecting cable above to be changed to parallel, not zigzag like a series battery connection
What is the Led matrix library do you use? Some libraries has the option for connecting panels this way.
Thanks, I'll give it a try
Does it support Arduino and ESP?
No
This only as example.
Other libraries also supports this way of connection.
For ESP32 see
How about HUB 15?
HUB15 ? - I have not seen such a connector. Please show the link to the HUB15 panel if you have it.
Perhaps HUB12 ?
Did you find the code?
This is HUB12 connector< used for monochrome panels.
Yes, my library supports this with STm32 and RP2040 boards
I just found the DMD.h library to make panels from zigzag to parallel, I haven't tried it yet
Multiple panels
https://rweather.github.io/arduino-projects/classDMD.html
