Help to continuous run the ultrasonic even the car was turning right or left. Becauses when the car is turning right the ultrasonic is stop scanning h
#include <NewPing.h>
#include <Servo.h>
//Ultrasonic Sensor
#define RIGHT_TRIG_PIN A1
#define RIGHT_ECHO_PIN A0
#define CENTER_TRIG_PIN A3
#define CENTER_ECHO_PIN A2
#define LEFT_TRIG_PIN A5
#define LEFT_ECHO_PIN A4
#define MAX_DISTANCE 200
NewPing right(RIGHT_TRIG_PIN, RIGHT_ECHO_PIN, MAX_DISTANCE);
NewPing center(CENTER_TRIG_PIN, CENTER_ECHO_PIN, MAX_DISTANCE);
NewPing left(LEFT_TRIG_PIN, LEFT_ECHO_PIN, MAX_DISTANCE);
//Rigth motor
#define in1 3 //Motor1 L298 Pin in1
#define in2 4 //Motor1 L298 Pin in2
//Left motor
#define in3 5 //Motor2 L298 Pin in3
#define in4 6 //Motor2 L298 Pin in4
//Servo
Servo servo1; //hand servo
Servo servo2; //hand servo
Servo servo3; //grip servo
Servo servo4; //grip servo
int pos = 0;
int pos1 = 0;
servo1.attach(11); //hand servo
servo2.attach(10); //hand servo
servo3.attach(9); //grip servo
servo4.attach(8);
servo1.write(60);
servo2.write(120);
servo3.write(20);
servo4.write(160);
int rightDistance = right.ping_cm();
int centerDistance = center.ping_cm();
int leftDistance = left.ping_cm();
Serial.print("Right: ");
Serial.print(rightDistance);
Serial.print("cm");
Serial.print(" Center: ");
Serial.print(centerDistance);
Serial.print("cm");
Serial.print(" Left: ");
Serial.print(leftDistance);
Serial.println("cm");
delay(15);
Forward();
if(centerDistance <= 10){
Stop();
Backward();
Stop();
myServo();
if(rightDistance > leftDistance){
Serial.println("Left");
Stop();
turnRight();
else{
Serial.println("Right");
Stop();
turnLeft();
if (rightDistance <= 10){
Stop();
turnRight();
if( leftDistance <= 10){
Stop();
turnLeft();
//-----------------Servo Setup------------------------------
void myServo(){
for (pos = 60, pos1 =120 ; pos <= 165, pos1>=15; pos += 2, pos1-=2 ) { // goes from 90 degrees to 180 degrees
// in steps of 1 degree
servo1.write(pos);
servo2.write(pos1);
delay(15); // waits 15 ms for the servo to reach the position
for(pos = 20,pos1 = 160; pos <=90, pos1>=90; pos +=2, pos1-=2){
servo3.write(pos);
servo4.write(pos1);
delay(15);
for (pos = 165, pos1 = 15; pos >= 30 , pos1<=150; pos -= 2, pos1+=2 )
servo1.write(pos);
servo2.write(pos1);
delay(15);
for(pos = 90,pos1 = 90; pos >=20, pos1<=160; pos-=2, pos1+=2){
servo3.write(pos);
servo4.write(pos1);
delay(15);
servo1.write(60);
servo2.write(120);
servo3.write(20);
servo4.write(160);
//-----------------Motor Setup------------------------------
void Stop(){
digitalWrite(in1, 0); //Left Motor backward Pin
digitalWrite(in2, 0); //Left Motor forward Pin
digitalWrite(in3, 0); //Right Motor forward Pin
digitalWrite(in4, 0); //Right Motor backward Pin
void Forward(){ //forward
digitalWrite(in1, 255); //Left Motor backward Pin
digitalWrite(in3, 255); //Right Motor forward Pin
void Backward(){ //Backward
digitalWrite(in2, 80);
digitalWrite(in4, 80);
void turnLeft(){ //turnLeft
digitalWrite(in1, 125);
digitalWrite(in4, 125);
void turnRight(){ //turnRight
digitalWrite(in2, 125);
digitalWrite(in3, 125);
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description is clearly
:warning: DO NOT CREATE TOPICS IN THIS CATEGORY :warning:
The topic has been moved to the Programming category
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Your for loop syntax semantics needs some attention
Your code is full of delays, this is a common beginner mistake. 'Delay' means 'do nothing' for some time period. Doing nothing includes not doing the ultrasonic scanning.
You need to understand the principals of millis for timing, state machines and non-blocking code.
The tutorials that will help you are these (and maybe some others I didn't think of):
Using millis for timing
Demonstration for several things at the same time
Finite state machine tutorial
And please, edit your code to use code tags; select the code in your post, click on <code/> in the tool bar.
Thnk you ..im learning millis right now
You might also find this useful:
Although it is about flashing LEDs the principles are the ones you need to learn.
can you explain this better.
When the car is turning left or right the ultrasonic sensor is stop scanning
So why is the topic marked "solved"?
