Hello everyone, I hope you all are alright. I decided to look for some help here since it's been quite difficult to find out about what the problem is with this circuit. You see, my friend and I are really, and I mean really new to all of this, and we were tasked by our teacher to:
"Generate a story that involves using a single Arduino, at least three (different) sensors, and at least two different actuators (one must be a servo motor). The story must be tested by using TinkerCad. Only one Arduino can be used, and there must be some relationship between at least two variables to activate an actuator.
When I refer to history, it's something like: "The parking system at the Unit where I live already has each of the parking spaces assigned, but during the day, many remain empty, and many visitors want to use them temporarily. This would improve security for visitors to the unit. It's also important to maintain automatic lighting in each parking bay. The system I intend to design allows the gatekeeper to be notified whenever there is a free parking space by the illumination of an LED on a console, and by pressing a button, the gatekeeper can activate the fence that rises and lowers to let the car through. Likewise, the parking lot light must be turned on or off depending on the lighting level.
For this, I require:
A photocell: ...described as
how the photocell works
A proximity sensor: ...described as how the proximity sensor operates
A servomotor: ...described as and how the servomotor operates
THE PREVIOUS EXAMPLE CANNOT BE USED
ONLY TINKERCAD BLOCK CODE CAN BE USED"
We decided to do this with an Automatic Food Dispenser for pets: Contextual Narrative:
In homes where owners are not always present when feeding their pets, there is a need for an automated system that ensures optimal food delivery. This project simulates an automatic feeder that operates only during the day, when the food level is low and the pet sitter (simulated by a button) indicates it's feeding time. The system does not depend on the pet's presence, making it ideal for homes with changing routines.
Sensors Used:
Potentiometer (Level Sensor): Simulates the food level in the tank. If the level is low, the tank is considered to need refilling.
Photoresistor (LDR): Detects if it's daytime. The system only works with sufficient light.
Button (simulates feeding time): The sitter presses it to indicate it's time to dispense food.
Actuators Used:
SG90 Servo: Opens the hopper to dispense food.
LED: Visually indicates that dispensing has been completed.
Relationship between variables:
The system activates the servo and the LED only if three conditions are met simultaneously:
The food level is low (level < level_threshold)
The button is pressed (button == HIGH)
There is enough light (light > light_threshold).
We tried to build the circuit, but the result is that basically only the potentiometer "releases food" and the button and the photoresistor do nothing. It would be really helpful if someone could tell us what's going on. Thank you in advance. (Pict.01: Circuit, Pict.02: Block code.)
