Hey again everyone. I could have put this in a previous post however my question is slightly different to the last. Im going to put the entire code below but I'm only confused with one thing...
#include <TimerOne.h>
int latchPin = 8; //Pin connected to Pin 12 of 74HC595 (Latch)
int clockPin = 12; //Pin connected to Pin 11 of 74HC595 (Clock)
int dataPin = 11; //Pin connected to Pin 14 of 74HC595 (Data)
byte led[8]; // 8 element unsigned integer array to store the sprite
pinMode(latchPin, OUTPUT); // set the 3 digital pins to outputs
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
led[0] = B11111111; // enter the binary representation of the image
led[1] = B10000001; // into the array
led[2] = B10111101;
led[3] = B10100101;
led[4] = B10100101;
led[5] = B10111101;
led[6] = B10000001;
led[7] = B11111111;
// set a timer of length 10000 microseconds (1/100th of a second)
Timer1.initialize(10000);
// attach the screenUpdate function to the interrupt timer
Timer1.attachInterrupt(screenUpdate);
for (int i=0; i<8; i++) {
led[i]= ~led[i]; // invert each row of the binary image
void screenUpdate() { // function to display image
byte row = B10000000; // row 1
for (byte k = 0; k < 8; k++) {
digitalWrite(latchPin, LOW); // open latch ready to receive data
shiftIt(~led[k] ); // shift out the LED array (inverted)
shiftIt(row ); // shift out row binary number
// Close the latch, sending the data in the registers out to the matrix
digitalWrite(latchPin, HIGH);
row = row >> 1; // bitshift right
void shiftIt(byte dataOut) { // Shift out 8 bits LSB first, on rising edge of clock
boolean pinState;
digitalWrite(dataPin, LOW); //clear shift register read for sending data
for (int i=0; i<8; i++) { // for each bit in dataOut send out a bit
digitalWrite(clockPin, LOW); //set clockPin to LOW prior to sending bit
// if the value of DataOut and (logical AND) a bitmask
// are true, set pinState to 1 (HIGH)
if ( dataOut & (1<<i) ) {
pinState = HIGH;
else {
pinState = LOW;
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
digitalWrite(clockPin, HIGH); //send bit out on rising edge of clock
digitalWrite(clockPin, LOW); //stop shifting
What I do not get is the need for row. From what I gather, B10000000 represents the first row on the 8x8 led dot matrix display, and say B00000100 would be the 6th row. First of all, I dont understand how that binary number represents the row.
From what I was thinking, the function shiftIt(led[k]) (with the not symbol) set each pinState to either a HIGH or al LOW so that the image could be conveyed. I can't get my head around calling the same function and passing the row as a parameter...Thank you for reading and hopefully you can help me understand it correctly!
