HI ALL I Have Issues on my program I have 1 Stepper Motor Kit Nema 34 8.0Nm Stepper Motor and 2 buttons 2 limit switches
#define LIMIT_SWITCH_1 9
#define LIMIT_SWITCH_2 10
#define SWITCH_1 11
#define SWITCH_2 12
#define DIR_PIN 6
#define EN_PIN 5
#define PUL_PIN 7
#define WAITING_TIME 2000
pinMode(DIR_PIN, OUTPUT);
pinMode(EN_PIN, OUTPUT);
pinMode(PUL_PIN, OUTPUT);
pinMode(LIMIT_SWITCH_1, INPUT_PULLUP);
pinMode(LIMIT_SWITCH_2, INPUT_PULLUP);
pinMode(SWITCH_1, INPUT_PULLUP);
pinMode(SWITCH_2, INPUT_PULLUP);
digitalWrite(EN_PIN, LOW);
void movement_clockwise() {
digitalWrite(DIR_PIN, HIGH); // SET DIRECTION
for (int i = 0; i < 10000; i++) {
digitalWrite(PUL_PIN, HIGH);
delayMicroseconds(500);
digitalWrite(PUL_PIN, LOW);
// Check the limit switch during movement
if (digitalRead(LIMIT_SWITCH_1) == LOW) {
 delay(WAITING_TIME);
  break; // Exit loop if the limit switch is triggered
 if (digitalRead(SWITCH_1) == HIGH) {
void movement_counterclockwise() {
digitalWrite(DIR_PIN, LOW); // SET DIRECTION
if (digitalRead(LIMIT_SWITCH_2) == LOW) {
  if (digitalRead(SWITCH_2) == HIGH) {
void movement_handler() {
if (digitalRead(LIMIT_SWITCH_1) == LOW) { movement_counterclockwise();}
else if (digitalRead(LIMIT_SWITCH_2) == LOW) { movement_clockwise();}
else {movement_clockwise();} // Default movement (e.g., clockwise)
movement_handler();
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
You have not said what your issues are
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
#define SWITCH_1   11
#define SWITCH_2    12
#define DIR_PIN            6
#define EN_PIN             5
#define PUL_PIN            7
  movement_handler();
You managed to post using code tags but have not described your issues ?
What is the code meant to do ?
What does it actually do ?
I have issues with your post !
No schematics or block diagram, what’s the problem you’re having ?
Better questions get better answers.
I Have 2 buttons 2 limitswitches
ISSUE : The Switch is not responding when i press
when button 1 is turn on the motor will move clockwise ,ones it reaches the limit switch 1 it will stop .Continue loop
when you press the button 2 the motor will move counter clockwise ,ones it reaches to the limit switch 2 it will stop. Continue loop
/////FINALPROGRAM ELEVATOR CONTROL 2C LIMIT SWITCHS...
#define SWITCH_1   11
#define SWITCH_2    12
#define DIR_PIN            6
#define EN_PIN             5
#define PUL_PIN            7
  movement_handler();
We need to see a circuit diagram and I don't mean a 'photo of a mess of wires
Please draw the circuit, using pencil and paper is good enough, showing how all components are connected, pin numbers and how the project is powered. Upload a photo of the drawing
Debug using serial monitor; print out the status of your buttons and limit switches and see if the do what they are supposed to do.
You can write a simple test program that does not involve the stepper to test buttons and limit switches.
Hi, @wire12
What is with using pin 5 as enable, but not using the enable terminals on the stepper driver?
Tom.... :smiley: :+1: :coffee: :australia:
i connect already but still not working
