How to close or hide the "Output" panel
G'day, all.
I had retinal eye surgery last Autumn, and am overdue for cataract surgery. I need new glasses, but it does not make sense for me to get them until after I have the cataract surgery. All this is to explain that my eyesight ain't so good, at the moment.
(There's a reason why my chosen moniker, "DuinoSoar," is almost like dinosaur; you know, those ancient, old creatures. And, yes, I know that pteranodons were not really dinosaurs, but the cartoon pterodactyl is my chosen icon and I am sticking to it. :wink: )
I am using Arduino IDE 2.0 with the "High Contrast" theme, and need to also use larger fonts in the editor window. However, when I expand the font size, the minimum size of the Output window also gets larger and takes up more "real estate," reducing the size of the source code editor window.
I really only want the Output window when I need it (e.g. when compiling and uploading my application), NOT while I am writing and editing code.
I tried to look for how to close or hide the Output window, but cannot seem to find it.
So how do I close or hide the Output window in IDE 2.0?
Thanks and best regards,
DuinosSoar.
Your topic was MOVED to its current forum category as it is more suitable than the original
Thanks, @UKHeliBob. I was not sure I was posting in the correct forum and I am grateful that you moved it to the right one.
Hi @DuinoSoar. The control for toggling the visibility of the bottom panel that contains the "Output" and Serial Monitor views is here:
The Arduino IDE developers are tracking the problem of this control not being very intuitive here:
Thank you so much, @ptillisch. That works just fine. I appreciate you posting the answer. As your post suggests, it was not very intuitive. I was looking up in the menus, but did not find anything there.
You are welcome. I'm glad if I was able to be of assistance.
Regards, Per
I found an alternative way of doing it (if you're still interested): Simply double click on the file name to remove/replace the output area. See image below.
