Hello I have problem connecting Attiny85.
How do i use breadboard and resistors and power supply to make led Blink.
I'm using sparkfun programmer and the Attiny85 is programd to Blink.
Not sure what on earth your problem could be. It is exactly the same as using a normal Arduino only you have fewer pins.
What he said...
Thanks for the answer should i use 5v in the breadboard and resistors?
Some tips how Wire the circit and use jumper Wire?
For an RGB LED you need three resistors one for each colour.
Is it a common anode or common cathode LED?
If it is a common anode connect it to the +5V and the resistors connected to the cathodes connect to three Arduino outputs.
If you have a common cathode then connect it to ground and the three resistors to Arduino output pins.
That picture is four LEDs, it is not an RGB LED like you said you had.
