Looking at the Nano manual it shows mounting holes 0.07 inches diameter. That's 1.77mm which means a M1.6 machine screw (metric type) would suit. I know these are stocked by many locations - depending where you are located a distributor of Pololu (link to their machine screw page) is one option. Spacers and/or standoffs to suit will be stocked at similar locations.
Thanks Geoff. Miniature screws seem irritatingly expensive over here (UK) - I'll keep looking on eBay, but I might see if I can get hold of a glue gun and experiment with that too...
museumoftechno:
I agree, and the fewer you buy the worse it gets. If you're in the UK try larger electronics distributors like Newark - I typically add mixed bags of of M3's of various lengths to my orders with their sibling Element 14 here and that works out pretty cost effective. Of course the hot glue gun should never be far from reach in my view too
museumoftechno:
Depends where you are. There's an old fashioned hardware shop near me (East London) that sells screws, bolts, nuts, washers, etc. loose. Earlier this week, I bought 20 * M4 15mm long bolts and 20 * M4 nuts for £1.56. I know they have 10BA bolts (small enough for you?) of various types (cheesehead, roundhead, countersunk, brass or steel, etc.) and lengths at about 50p for 10 for the bolts and less for the nuts.
They stock anything from 10BA up to about 1/2" Whitworth and wood screws from 1/4" No. 2 to 6" No. 12 (and bigger) all at reasonable prices. The smaller items sell in lots of 10 (counted by hand), the larger ones are sold individually.
They have an ecclectic mix of stuff. I'm going again next week to try to get some 6BA stand-offs. (I've got some, but they're too short). If they don't have them, I don't know who does.
It's the pre-packaged stuff that's expensive.
To mount a Nano -
M1.6 socket head cap screws (the only fixing with a small enough head).
M1.6 knurled insert nut (available on Ebay) 2.5mm od 4mm long.
Copper clad board.
Cut 2 pieces of copper clad board 22x7mm.
Drill 2 holes 2.5 dia at 15.24mm (0.6") crs.
Drill 1 centre hole and countersink the copper side to suit an M3 screw (countersunk because screw head is close to Nano).
Fit insert nut in each small hole, protruding proud of copper side, solder in place.
Voila - compact mounting feet for a Nano and not a 3d printer in sight.
Ensure pins do not come into contact with copper clad board.
museumoftechno:
10 BA screws are 1.7 mm diameter and can be obtained cheaply from any model engineering supplier in the UK. I use EKP Supplies (google them).
strykeroz:
Geoff
Maplins do a mixed kit that is fairly good value, of course its easy to use up one size screw quickly but cheap crimp pliers have a handy shear to cut the long ones down.
