Mounting Techniques for Arduino in Enclosure
I am aiming to mount my Nano 33 BLE (or Sense Rev2) inside of an enclosure. It will most likely be polycarbonate or some polycarbonate alloy and is being designed in CAD now (ABS is also an option). I need to pull accurate acceleration data from the IMU so need the component as rigidly fixed as possible.
I was going to mechanically fix it by creating a thread hole in the CAD rendering and getting nylon screws. However, the four holes on the corners of the nano measured to be 1.5mm, which does not correlate to any screw sizes I can find. Am I missing something or is this too small of a hole to use to mount the nano in this way?
I understand that some type of epoxy/resin adhesive could also work. If so, what type would people suggest so that it does not interfere with the Nano in any destructive way. If you could provide a link, that'd be great!
If you have any other suggestions for rigidly fixing this outside of what I mentioned, feel free to let me know as these are the only two routes I am working with.
The drawing states 1.65mm for the mounting holes so theoretically an M1.6 X 0.35 would fit.
A #0 screw would fit better if you have access to them.
Make slots for it to slide into place, maybe even clip into the holes .
Have a look around to see what others have done
Thanks, I could not locate the drawing so I had to use my calipers, which would not fit inside the hole, so an exterior estimate was used. Where can I find the drawing?
I don't have a sufficient knowledge regarding screw sizes - what is the size difference between this M1.6 and #0 (wondering why you think the 0 is better)
That's another idea I'm running with - slots with a tight friction fit. Or a looser fit with some epoxy to fill in any potential open space to ensure that it is rigidly fixed - any movement will interfere with the data collection of course
Me neither. But here where I live we have google, which lets me know until I forget that a #0 screw is 0.060 inches nominal diameter or 1.524 millimeters.
HTH
a7
Maybe something from the top row here: board edge mount at DuckDuckGo
Suggest you consider these techniques:
Also, see this showing mounting:
Make an insert out of thin clear Plexiglass. If you err slightly you do not leave hogged out holes clearly visible on the outside of the box.
Nylon or brass standoffs screwed to the modules, then glued to the floor of the case.
Use Libre Office Draw or Open Office Draw to make a template. Put a + in the middle of the mounting hole as a drill guide. You have the option to print it backward and iron it on to a metal surface as a template. You can fuss and fiddle with the size percentage setting to get the final version more accurate than you can drill.
Drawing
The #0 screw is 0.1mm smaller diameter than the M1.6 so should fit the hole properly.
kapton tape
If only a certain stubborn and arrogant country had been able to overcome the natural resistance to change, and adopted the metric system.
And no, I am not talking about Liberia or Myanmar. :expressionless:
a7
Oh, I agree. 1.5876mm is so much easier for me to remember than 1/16." :sunglasses:
@jeremych
Actually, there is a handy rule of thumb that I use to remember what fractional size a # screw is. Starting with #0 which is 1/16 or 4/64. #1 is + 1/64 or 5/64. #2 is 6/64 or 3/32. etc. I can't remember if it breaks down at some point but if one cared they could calculate it.
After digging a little deeper I find there are smaller metric screws. 1.0mm, 1.2mm, and 1.4mm. Use one of those if they are available.
remember 1.5876mm
don't have to. You've already found the logical
It's so much easier to remember.
See, you're already on the verge of enlightenment! Come on out into the sun.
Isn't, at least not according to every chart I saw googling.
1/16" is the nearest convenient fraction; the standard is 0.060 inches, not 0.0625 or even 0.062.
a7
Those are kind of neat. I could 3D print some of those.
Rules of thumb are like that.
BluTack
