I bought an electrect microphone at Sparkfun (datasheet) and built the following circuit.
When I hook it up to a professional audio interface it works but I'm having a few problems that I need to solve.
Problem 1: I'm picking up a lot of 60Hz hum. None of my other pro mics that I hook up to the audio interface pick this up so I'm positive it's coming from my circuit. To be fair, the pro mics cost up to $2K so I'm sure they have some built-in magic to prevent this. Or maybe -most likely- I'm doing something wrong since this is my first audio circuit ever.
In order to solve this I tried adding this high pass filter that I found on Google:
What happened when I tried the high pass filter was that the sound does indeed loose a lot under 150Hz but it also looses power and the signal arriving at the audio interface is very weak. Not only that, the hum is still there. It sounds like the signal from the mic is filtered but not the hum.
**Problem 2:**The signal from the mic should never reach the audio interface unless I press a button (this is called a "talkback mic" in recording studios). So I tried adding a switch like in this schematic:
The problem with this is that while it kills the signal from the mic, the hum is still there so it's not completely cutting the signal. When I added two switches to both ends of the battery, the signal and the hum go away. Is this the proper way of "killing" the circuit or should I use a DPST switch?
