Hi
I'm developing a scale and I'm not understanding what's wrong.
The components are:
- ESP32 (supply by USB)
- HX711 controller (supply by 5v ESP out)
- 4 Strain Gauges
- upper right and lower right with black wire
- upper left and lower left with black wire
- lower right and lower left with white wire
- upper right and upper left with white wire
- E+ red wire from lower right
- E- red wire from upper left
- A+ red wire from upper right
- A- red wire from lower left
I had to solder the strain gauges and HX711 controller to avoid cables issues but now I'm not reading value.
I've checked many times the links between them and they are correct. The values coming from the sensors are 0.
What do I expect reading the voltage for each component?
What do I check to ensure the correct hw setting?
- I tested the voltage between HX711 VCC and Ground and it was 5v.
- I tested the voltage between HX711 Data and Ground and it was near 0v
- I tested the voltage between HX711 E+ and Ground (without Strain Gauges) and it was a bit lower than 5v
- I tested the voltage between HX711 E- and Ground (without Strain Gauges) and it was a bit lower than 5v
- I tested the voltage between HX711 A+ and Ground (without Strain Gauges) and it was 0v
- I tested the voltage between HX711 A- and Ground (without Strain Gauges) and it was 0v
- Next, I linked the E+, E-,A+, A- with the Strain gauges (in the following order lower right, upper left, upper right, lower left) and I tested the voltage each one and Ground and all is about 0.7 v
Before unsolder and soldering again, I've done it at least 3 times, I'd like to measure the voltage to isolate if there's a problem with the controller or the sensors.
In the beginning, I read value with the same code but there were many issues with the links and for that reason, I started to solder all cables to avoid contact problems.
The code I'm using is reported below (I started from Github example HX711_ADC Calibration.ino and I added 2 led to monitoring the values read)
HX711_ADC
Arduino library for HX711 24-Bit Analog-to-Digital Converter for Weight Scales
Olav Kallhovd sept2017
Settling time (number of samples) and data filtering can be adjusted in the config.h file
For calibration and storing the calibration value in eeprom, see example file "Calibration.ino"
The update() function checks for new data and starts the next conversion. In order to acheive maximum effective
sample rate, update() should be called at least as often as the HX711 sample rate; >10Hz@10SPS, >80Hz@80SPS.
If you have other time consuming code running (i.e. a graphical LCD), consider calling update() from an interrupt routine,
see example file "Read_1x_load_cell_interrupt_driven.ino".
This is an example sketch on how to use this library
#include "information_led.h"
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
#define SCK_DELAY 1
#define SAMPLES 32 //default value: 16
//pins:
const int HX711_dout = 4; //mcu > HX711 dout pin
const int HX711_sck = 5; //mcu > HX711 sck pin
//output led
const int LED_RED = 2; //mcu > HX711 dout pin
const int LED_GREEN = 15; //mcu > HX711 sck pin
InformationLed redLed(LED_RED);
InformationLed greenLed(LED_GREEN);
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
void calibrate() {
Serial.println("***");
Serial.println("Start calibration:");
Serial.println("Place the load cell an a level stable surface.");
Serial.println("Remove any load applied to the load cell.");
Serial.println("Send 't' from serial monitor to set the tare offset.");
boolean _resume = false;
while (_resume == false) {
LoadCell.update();
if (Serial.available() > 0) {
char inByte = Serial.read();
if (inByte == 't') LoadCell.tareNoDelay();
if (LoadCell.getTareStatus() == true) {
Serial.println("Tare complete");
_resume = true;
Serial.println("Now, place your known mass on the loadcell.");
Serial.println("Then send the weight of this mass (i.e. 100.0) from serial monitor.");
float known_mass = 0;
_resume = false;
LoadCell.update();
known_mass = Serial.parseFloat();
if (known_mass != 0) {
Serial.print("Known mass is: ");
Serial.println(known_mass);
_resume = true;
LoadCell.refreshDataSet(); //refresh the dataset to be sure that the known mass is measured correct
float newCalibrationValue = LoadCell.getNewCalibration(known_mass); //get the new calibration value
Serial.print("New calibration value has been set to: ");
Serial.print(newCalibrationValue);
Serial.println(", use this as calibration value (calFactor) in your project sketch.");
Serial.print("Save this value to EEPROM adress ");
Serial.print(calVal_eepromAdress);
Serial.println("? y/n");
_resume = false;
if (inByte == 'y') {
EEPROM.begin(512);
#endif
EEPROM.put(calVal_eepromAdress, newCalibrationValue);
EEPROM.commit();
#endif
EEPROM.get(calVal_eepromAdress, newCalibrationValue);
Serial.print("Value ");
Serial.print(" saved to EEPROM address: ");
Serial.println(calVal_eepromAdress);
_resume = true;
else if (inByte == 'n') {
Serial.println("Value not saved to EEPROM");
_resume = true;
Serial.println("End calibration");
Serial.println("To re-calibrate, send 'r' from serial monitor.");
Serial.println("For manual edit of the calibration value, send 'c' from serial monitor.");
void changeSavedCalFactor() {
float oldCalibrationValue = LoadCell.getCalFactor();
Serial.print("Current value is: ");
Serial.println(oldCalibrationValue);
Serial.println("Now, send the new value from serial monitor, i.e. 696.0");
float newCalibrationValue;
newCalibrationValue = Serial.parseFloat();
if (newCalibrationValue != 0) {
Serial.print("New calibration value is: ");
Serial.println(newCalibrationValue);
LoadCell.setCalFactor(newCalibrationValue);
_resume = true;
_resume = false;
EEPROM.begin(512);
#endif
EEPROM.commit();
#endif
_resume = true;
_resume = true;
Serial.println("End change calibration value");
Serial.begin(115200); delay(1000);
Serial.println("Starting...");
LoadCell.begin();
unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
LoadCell.start(stabilizingtime, _tare);
if (LoadCell.getTareTimeoutFlag() || LoadCell.getSignalTimeoutFlag()) {
Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
while (1);
else {
LoadCell.setCalFactor(1.0); // user set calibration value (float), initial value 1.0 may be used for this sketch
Serial.println("Startup is complete");
while (!LoadCell.update());
calibrate(); //start calibration procedure
static boolean newDataReady = 0;
const int serialPrintInterval = 0; //increase value to slow down serial print activity
// check for new data/start next conversion:
if (LoadCell.update()) newDataReady = true;
// get smoothed value from the dataset:
if (newDataReady) {
if (millis() > t + serialPrintInterval) {
float i = LoadCell.getData();
Serial.print("Load_cell output val: ");
Serial.print(" ");
Serial.println(i);
if( isnan(i) ){
Serial.println(digitalRead(HX711_dout));
redLed.SwitchON();
greenLed.SwitchOFF();
}else{
redLed.SwitchOFF();
greenLed.SwitchON();
newDataReady = 0;
t = millis();
//receive command from serial terminal
if (inByte == 't') LoadCell.tareNoDelay(); //tare
else if (inByte == 'r') calibrate(); //calibrate
else if (inByte == 'c') changeSavedCalFactor(); //edit calibration value manually
// check if last tare operation is complete
