My Question is. Have I feed it with a external battery water pump. Or I can use a transistor and increase 5v to 12 V what I get relay.
Water Pump is 12V
Mi rele is 5V DC
Water Pump is 12V
Mi rele is 5V DC
Try sticking to one thread about the same thing. It just so happens your original post with the same question is one post down...
man... I don't understand what you want to achieve?
Topic =
I have a rele 5V DC and I want to control a water pump
Do you want to control a water pump using a 5V relay?
Answer = You can
Subject=
You want to power the relay using an external battery water pump?
-or-
You want to increase voltage from 5V to 12V using a transistor?
Answer = You can power the relay using a battery but not with a water pump. Use a boost converter to increase voltage.
That eBay link is for a pump requiring 2.5 to 6v, not 12v.
