Hey ARDUINO guys,
Can anyone help me how I can build a USB and other cable tester using an Arduino board application?!
any replies asap
Marcel Dalli
Malta EU
Hey ARDUINO guys,
any replies asap
Marcel Dalli
Malta EU
What parameters of the cables do you want to test?
@maldali ,
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
Hi Jim. tks for replying,
I need to test just that the cables are working well
I need to just check that the cable/s are workinh well re conductivity
Google "Arduino cable continuity tester" you will see hundreds of examples on this forum and others.
So you do not want to test USB-C PD functioning? I have a continuity tester as well as a full functioning cable tester, the full functioning has a LOT of parts.
The continuity tester is simple and examples can be found with Google. The full function is more advanced.
A battery and LEDs and resistors and proper connectors are all you need. Absolutely NO reason for an Arduino. Should be able to build in 1/2 an hour.
Start with one board containing two mating connectors. The code will test each wire for continuity and shorts. Complexity becomes exponential in wiring and testing adding just one more cable, so make each tester a single-cable tester.
Or save time and purchase one:
https://www.amazon.com/MFL-Rectangular-13-Plug-Checker-Tracker-Indicators/dp/B0972J2ZR9
