Hello. i am trying to create a project about design & create Surge Arrester Monitoring AC Voltage 115kV using ESP32 + Adafruit SH1106 + ADS1115 + AD620. Measure use HFCT to clamp at ground line from Arrester to measure leakage current like this
i want to measure leakage current at milliampere (mA) and show on OLED
i really need more information , circuit correct connect & or use component , or If it is possible, could anybody give a code or any suggestion to help me achieve it? I am a really newbie. Thank so much
@gilshultz sry for late reply. really want to make for portable and can measure monitoring application wireless in smartphone at a cheap way as possible.
Note the data on your detector states 600V Maximum! Unless I am missing something I would recommend you not use it but get an appropriate one for your voltage.
@gilshultz i use CT clamp to measure and monitoring leakage current from 115kV arrester by CT clamp at Earth current line as follow my example image
in theory as i research. CT clamp are send leakage current signal output as analog. so i want to use that analog signal from CT clamp connected to ESP32 for receive and display at OLED (as a following my code)
so what i really need to is "CT Clamp Leakage Current Sensor"part for direct connect as ESP32
can you provide Leakage Current sensor are "appropriate one" for it?
