I will design PCB which is inserted Arduino micro(CODE:A000053)
But I can't know the dimension of Arduino micro.
Arduino micro is soldered pin-headers .
I can't know the size of pin-headers too. So , I can't design PCB.
Could you tell me about the below question?.
I wrote the detail of question to excel files.
Q1:Could you tell me the dimension of Arduino Micro(code A000053) ?
Q2:Could you tell me the dimension of Pin-headers ?(??mm x ??mm)
Q3:Could you tell me a height of Arduino Micro(??mm)
pert
3
Some dimensions of the Arduino Micro are listed on the "Tech specs" tab of its product page:
Length 48 mm
Width 18 mm
That length is the size of the PCB only. The USB socket extends an additional 1 mm, bringing the total length to 49 mm.
The height of the Pro micro, including the pin headers on the bottom of the board as well as the ICSP header on the top of the board is 18 mm.
These measurements are from an official Arduino Micro I just received a few weeks ago. Please let me know if there are any other dimensions you need.
Dear Mr. pert
Thank you for reply to my question.
I wrote the detail dimension which I want to know to attached file.
Could you check it??
Dear Mr. UNOGuy
I write the unknown dimension to picture.(No.①-No.⑱)
Is there invisible?
