IDE hangs on startup: "library_index.json: The system cannot find the file specified"
2 posts were split to a new topic: IDE hangs on startup: "No connection established"
4 posts were split to a new topic: IDE hangs on startup
A post was split to a new topic: IDE hangs on startup
4 posts were split to a new topic: IDE hangs on startup: "Error loading hardware platform: discovery builtin:serial-discovery not found"
4 posts were split to a new topic: IDE hangs at startup: "Error: Could not find menu with menu-path: ..."
3 posts were split to a new topic: IDE hangs on startup
4 posts were split to a new topic: IDE hangs on startup: "Unable to get Documents Folder: The system cannot find the path specified."
2 posts were split to a new topic: IDE hangs on startup: "Error loading hardware platform: discovery teensy:teensy-discovery not found"
A post was split to a new topic: IDE hangs on startup: "Error loading hardware platform: discovery builtin:serial-discovery not found"
2 posts were split to a new topic: IDE hangs on startup: Why in the world does it download things before it's even loaded?
A post was split to a new topic: IDE hangs on startup: "Unable to get Documents Folder: The system cannot find the path specified."
3 posts were split to a new topic: IDE hangs on startup: "Error loading hardware platform: discovery builtin:serial-discovery not installed"
A post was merged into an existing topic: IDE 2.2.1 main window randomly goes blank
A post was split to a new topic: IDE hangs on startup: "discovery builtin:serial-discovery not found"
A post was split to a new topic: IDE hangs on startup: "connectex: An attempt was made to access a socket in a way forbidden by its access permissions."
