Identify/programm Attiny on tamiya rc light controller
Hello together,
I am currently trying to reprogram a purpose build, cheap, tamiya rc led controller.
It takes 3 PWM channels as input and then switches 6 LED channels on/off depending on logic.
I do not really like the integrated logic.
So I opened it up and found an unmarked iC. Tracing and measuring the different pins, I am pretty sure that this is some kind of Attiny board.
  • Pin 4 seems to be reset, tied to VCC to block a reset.
  • Pin 11 is tied to GND, dont know why?
  • The LEDs are sink driven
I disconnected Pin 4 from VCC and was able to reset the board with it. Visible becasue the rythmic blinking of the LED does reset and start from the beginning when I pull it to ground.
From the rest of the pinout it looks like a attiny 44/84. But I am not able to read the signature.
I tried with avrdude using an ArduinoISP2 and a CH341a.
I also tried using NPN Resistor with 12 V source to do a high voltage reset.
But whatever I try I do not get a valid signature. (00 00 00).
Maybe I am wrong with my Attiny assumption? Maybe someone have some more insight?
If all fails, I might just replace the controller.
Thanks in advance, best regards
Probably the easiest solution. Build your own with an ATtiny.
Short update here, I tried TPI programming with an Arduino nano real quick.
But so far I was not successful in getting a sigbature. But it seems the controller switches in a different mode when being reset by the tpi programmer, so maybe I am on the right track.
