Hello everyone.
I must begin with an apology for being a total newbie. I've been reading about Arduino for the past two years, thinking about possible applications for my work (photo and video), but I have no practical experience with electronics or robotics. I'm sure the project I have in mind will seem very simple for many of you here, so I hope some of you can help. Here it goes:
I'll be using a camera triggering product called MIOPS Smart which has on-board capabilities to fire a camera's shutter and/or flash as a result of sound activation, changes in light levels (lightning) or laser beam interrupt.
Most interestingly, the MIOPS also provides an extra input (3.5mm jack) that may be used for DIY custom applications with other types of sensors.
I intend to use the MIOPS for nature photography, so in some scenarios laser beam may not be the best option, as it can be seen and may disturb wildlife or show up in the images (also, the MIOPS has an optical sensor for the laser beam, but the emitter has be to sourced elsewhere). I think Infra Red would be better in some situations, or perhaps distance ranging might work. Other options (speculative at this point) would be pressure/weight activation, or humidity activation.
So the idea would be to build some type of Arduino controlled box where I may connect an Infra-Red emitter and sensor with enough distance between them to make an actual path an animal may cross, be it a small insect or a large mammal, and possible using other types of sensors as mentioned, then have the Arduino output a signal to be fed into the MIOPS via the 3.5mm port. There would be no need for the Arduino to control what happens in the camera (triggering, number of shots, interval, is the job of the MIOPS unit).
I now copy relevant instructions for this type of DIY setup from the MIOPS operating manual:
"The DIY port has three terminals. The first terminal is the ground terminal. The ground of the sensor must be connected to this terminal. The second terminal is the signal output terminal. The output signal from your sensor must be connected to this one. The third terminal is the power input terminal. If your sensor requires an external power source to work, MIOPS Smart can provide 3Volts to it through this port. You can feed your sensor from this port by observing the polarity. If the sensor is already powered from another source, you don’t need to make any connection through this terminal. (See diagram attached below).
Please note that, Miops Smart provides 3Volts to the sensor from this jack. The terminal in the front is where Miops Smart will feed the voltage. The output signal of the sensor must be connected to the first terminal of the jack.
The output signal can have a maximum value of 3.3 Volts. Using a sensor with higher voltage can damage the Miops Smart. Please make sure that the output jack of your sensor is compatible with the diagram shown.
After you have made sure, that your sensor has the correct terminal connections, you can connect the jack to the DIY port of the MIOPS Smart. The DIY mode has three different parameters. The first one is the threshold value. It is given in percentage and it reflects the required change in the signal level to initiate a triggering. As the input signal can be anywhere between 0 and 3.3 Volts, one percent change is equal to 0.033 Volts. You can set the threshold value per this calculation. The second parameter is the delay. As in the other modes, you can add some delay to the triggering event. The delay can be set to any value between 0 and 999 milliseconds.
The third parameter is called the “mode”. This parameter specifies how the output signal of the sensor should change to qualify as a trigger event. There are three options: Change, Rising, Falling. If you set the mode to change, it will not matter whether the voltage is going up or down. Any value above the threshold will qualify as a triggering event. If you want to detect increasing voltage only, the mode should be set to rising. And finally, if you set the mode to falling, you will only detect decreasing voltage changes."
That's all from the MIOPS manual.
I look forward to any suggestions for this setup forum members may provide. Thank you all in advance!
