Is it possible for arduino to press a button slightly?
I'm trying to make a steering wheel for some games and I want to find out can the arduino press a button slightly so it doesn't have to press the button with a higher rate?
do you mean using the arduino to physically control a button? with the right actuator it's possible. what's the button though? most of the ones I know of are ON or OFF - there is no "lightly" touch. Joystick would be something with more movement
you could measure the length of time a button is pressed or turn the steering wheel only while a button held down. presumably there is a left and right button.
There are multi step buttons that connect different connections as the button is pressed.
Idahowalker:
Got a link? I've never heard of such a button.
SteveMann:
Have a look at the "Canon N3 Camera Remote Shutter Release Cable Cord"
it's something you use to take pictures without touching your camera. A soft press is used to focus, and a hard press takes the picture. (like the shutter button on Reflex cameras)
When you open those up, it's very low tech (hence the price :slight_smile: ):
you have three metallic blades lined up with a small separator
and attached a different places
so when you "soft presss" you get blade 1 and 2 to connect and when you hard press blades 1,2 and 3 are touching each other.
You get three wires to the unit (green, blue, red) and you can handle green+blue as a "soft" momentary push-button and green+red as "hard" push button (blue getting activated too along the way).
So may be there are similar constructs out there serving different purpose... Never seen any though :slight_smile:
(images from my (French written) tutorial on how to Control your Camera (Canon) and a Cobra Flash with Arduino)
Look up, "2 stage buttons".
This is all very amusing, but we don't actually know what the OP actually wants to do
