It is possible to control a 24v BLDC Motor(brake,encoder) with Arduino?
Hello there!! :slight_smile:
I run a project an i would like to know if is possible to control a 24v BLDC Motor with Arduino.
I have 6 motor and i would like to cooperate its others. It is possible to control those motors with Arduino.
What connection should i make;
The idea is that the motion and position information will generate from Matlab.
Is that possible?
The motor model I have is on this link https://www.keyaservo.com/200w-400w-dc-servo-motors/57513748.html
Thank you for your time :slight_smile:
You can control such a motor with an Arduino, but it will need separate power and an appropriate driver. I note too, that it has an encoder, so if you're using six of them, make sure you get an Arduino with enough pins.
wildbill:
Hello wildbill thank you for your response :slight_smile:
Because i don't have many knowledge on this. ::slight_smile:
May you suggest me a appropriate driver for this motor?
Will I need 1 driver for each motor?
What about the power for the motor?
I am thinking 1 Arduino for 2 Motors. 6 Motors -> 3 Arduino
Maybe there is a guide I could collect information?
Thank you for your time!!
