Lcd 21 pin problems
Hi guys, I'm new here. I'm looking to find a solution about a 21 pin display. Let try to explain better.
How is possible to see from this 2 picture I would like to reuse this lcd with 7 digits. I suppose that is a 7 segment display, but I'm not sure. There are 21 pins but I can't understand what type of library I have to use and how I have to connect it to my Arduino board. Note that now the display is separated from the card, so I have 21 pins on the plastic transparent support.
Thanks for all the support guys.
Bye
Alex
Here it is the other picture
That's an interesting challenge. Looks like there are 50 segments on that display so the pins probably represent a 2D array with some common pins.
The best solution is to find a controller that will drive the display or a display with a controller that will do what you want. The LCD must have all of its signals average 0 volts. Putting DC on them will polarize the segment and cause it to stick on or off and drastically reduce its life. I know it is not the answer you want but I do not believe you have the skill set needed to accomplish this. Try this link: Segment LCD Displays: avoiding excessive DC component - Focus LCDs
