i'm having a similar problem as what was previously discussed here:
I tried doing what was written there, but still nothing works.
Have you tried the I2C scanner sketch?
Do you have the same exact set-up as @zarin12027, same parts and wiring?
Does not look like it, that is not an Uno and it looks like you have other things connected.
Please provide information on the components you are using and a diagram showing how they are connected.
Also post the code you are using, use code tags <CODE/>
#include <WiFi.h>
#include <WebServer.h>
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#include <DHT.h> // Adafruit library
// Pin Definitions
#define DHTPIN 4
#define DHTTYPE DHT11
#define DS18B20 5
#define BUZZER_PIN 2 // CHANGED: Moved from 13 to 2
#define REPORTING_PERIOD_MS 1000
// Health Thresholds
const float TEMP_HIGH = 38.0;
const float TEMP_LOW = 35.0;
const float BPM_HIGH = 120.0;
const float BPM_LOW = 50.0;
const float SPO2_LOW = 90.0;
float temperature, humidity, BPM, SpO2, bodytemperature;
const char* ssid = "Project123";
const char* password = "Password123";
DHT dht_sensor(DHTPIN, DHTTYPE);
PulseOximeter pox;
uint32_t tsLastReport = 0;
OneWire oneWire(DS18B20);
DallasTemperature sensors(&oneWire);
WebServer server(80);
// Heartbeat sound (short chirp)
void onBeatDetected() {
digitalWrite(BUZZER_PIN, HIGH);
delay(20);
digitalWrite(BUZZER_PIN, LOW);
pinMode(BUZZER_PIN, OUTPUT);
// --- STARTUP BEEP ---
// Confirms the buzzer is working on Pin 2 immediately
delay(200);
dht_sensor.begin();
sensors.begin();
WiFi.begin(ssid, password);
Serial.print(".");
server.on("/", handle_OnConnect);
server.onNotFound(handle_NotFound);
server.begin();
if (!pox.begin()) {
Serial.println("Pox Error - Skipping...");
pox.setOnBeatDetectedCallback(onBeatDetected);
pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
server.handleClient();
pox.update();
// Read Sensors
sensors.requestTemperatures();
temperature = dht_sensor.readTemperature();
humidity = dht_sensor.readHumidity();
BPM = pox.getHeartRate();
SpO2 = pox.getSpO2();
bodytemperature = sensors.getTempCByIndex(0);
// --- ALARM LOGIC ---
bool isEmergency = false;
// Check for abnormal vitals
// Only trigger if sensor values are "active" (above 10) to prevent false alarms when disconnected
if (SpO2 > 10 && SpO2 < SPO2_LOW) isEmergency = true;
if (bodytemperature > 10 && (bodytemperature > TEMP_HIGH || bodytemperature < TEMP_LOW)) isEmergency = true;
if (BPM > 10 && (BPM > BPM_HIGH || BPM < BPM_LOW)) isEmergency = true;
if (isEmergency) {
digitalWrite(BUZZER_PIN, HIGH); // Alarm stays ON
// Pin remains LOW (unless chirping in the onBeatDetected callback)
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
tsLastReport = millis();
Serial.print("BPM: "); Serial.print(BPM);
Serial.print(" | SpO2: "); Serial.print(SpO2);
Serial.print(" | BodyTemp: "); Serial.println(bodytemperature);
void handle_OnConnect() {
server.send(200, "text/html", SendHTML());
void handle_NotFound(){
server.send(404, "text/plain", "Not found");
String SendHTML(){
String ptr = "<!DOCTYPE html><html><head><meta name='viewport' content='width=device-width, initial-scale=1.0'>";
ptr +="<style>body{font-family:sans-serif; text-align:center; background:#f0f2f5;}";
ptr +=".card{background:white; padding:15px; margin:10px auto; border-radius:12px; width:85%; max-width:400px; box-shadow:0 4px 6px rgba(0,0,0,0.1);}";
ptr +="h1{color:#1a73e8;} .val{font-size:32px; font-weight:bold; color:#d93025;}</style></head><body>";
ptr +="<h1>Patient Monitor</h1>";
ptr +="<div class='card'><div>Body Temp</div><div class='val'>" + String(bodytemperature, 1) + " °C</div></div>";
ptr +="<div class='card'><div>Heart Rate</div><div class='val'>" + String((int)BPM) + " BPM</div></div>";
ptr +="<div class='card'><div>SpO2</div><div class='val'>" + String((int)SpO2) + " %</div></div>";
ptr +="<div class='card' style='font-size:14px; color:#555;'>Room: " + String(temperature, 1) + "C | " + String(humidity, 0) + "%</div>";
ptr +="</body></html>";
return ptr;
still max300102 LED did not light up. the code run successful but not reading for the heart beat rate and the oxygen level. Any solution for that problem?
zarin12027 used the MAX30105 library. Try the code zarin12027 used
i just run the code the max300102 LED light up now. Thank you
