It's not very clear what you're asking. If you're switching from a smaller segment display to LED strips you should be able to use the same circuit assuming it's capable of the larger amount of current that the LED strips require.
Give us some specs on the LED strip current requirements and show us what you have for a circuit now; we need a schematic (hand drawn if necessary).
my friend added code for 2 buttons to count up and down - that's all working, circuit works fine like it is... setup as common cathode currently, i tried using a uln2803 but i did not knwo where the common cathode lines must gomust go...
however i need to upscale to 50cm high digits
the 12v led strips are rated 14w per meter. i only want to use about 30cm per segment. so im guessing 1 segment will pull about 250ma
justcruzin:
i was thinking of using all 14 pins rather than multiplex?
then i can control each pin with a transistor? ( switch ground)
I agree, if this is for outdoor use, you need maximum brightness. That means no multiplexing.
If you are building these displays from strips, you can choose to make them common cathode or common anode.
If you make them common anode it will be easier.
With common anode, you can simply use an ordinary npn transistor for each segment (between the segment -ve and ground). BC337 would be ok for example. The Arduino pins (or shift register pins) can drive the transistor bases directly with 1K resistors to limit the base current. Alternatively use 2 x tpic6a595 high-current shift registers. The "a" variant can sink up to 350mA per pin.
With common cathode, its slightly trickier. You can use ordinary pnp transistors like BC327, between +12V and each segment +ve. But you can't drive the pnp bases directly with Arduino/shift register pins. They would be damaged by the 12V supply. So you would need an npn to pull each pnp base down and 10K to pull the pnp base up to 12V. Again, use 1K to limit the pnp base current and 4K7 to limit the npn base current. Alternatively use 2 x ULN2003/2803/tpic6c595 instead of the npn.
Your estimate of 250mA per segment may be too high. 30cm segments, assuming ordinary 60 leds/metre srtips, would need 60 * 0.3 * 20 / 3 = 120mA. Were you thinking of two parallel strips for each segment?
will you be able to draw a quick drawing on how to cconnect that transistor.. what i saw on most sites is some of the npn transistors dont have same pin out.
looking directly at the flat part of the bc337 ( as u view the digits) i see on google its says pins:
1-2-3 are C-B-E
justcruzin:
i struggle to find tpic6a595 in cape town
So buy them on eBay.
justcruzin:
i think im going to rather go bc337 - i see they 800ma
but if you look at his design. its pretty straight forward right?
Looks OK.
justcruzin:
The connections in that Instructible look OK. Can't believe I said that. They are normally terrible.
justcruzin:
1-2-3 are C-B-E
