#include <LiquidCrystal.h>
#include <math.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
const int backlightPin = 6;
int brightness = 0;
const int fadeLen = 768; // Duration of the fade in/out. Has to be a multiple
// of 256.
const int fridgeTempPin = A4;
const int freezerTempPin = A2;
const int piezoPin = 3;
const int timeFactor = 10; // realtime factor for debug. 1 means normal loop time.
const int switchPin = 2;
const int trendDelta = 1; // ºC difference until a trend change is decreted
int storedCnt = 0;
float avgFridgeTemp, prevAvgFridgeTemp, avgFreezerTemp, prevAvgFreezerTemp, sumAvgFridgeTemp, sumAvgFreezerTemp;
float storedFridgeTemp[12];
float storedFreezerTemp[12];
unsigned long loopMillis, lastStoreTempMillis, lastCalcTrendMillis;
//used to know what alarm is triggered
const int NO_ALARM = 0;
const int LOW_TEMP = 1;
const int HIGH_TEMP = 2;
const int CRITICAL_TEMP = 3;
int currFridgeAlarm = NO_ALARM;
int currFreezerAlarm = NO_ALARM;
int prevFridgeAlarm = NO_ALARM;
int prevFreezerAlarm = NO_ALARM;
byte fridgeAlarmChanged, freezerAlarmChanged, alarmAck;
// some custom smileys and symbols for the LCD
const int charDegree = 1;
byte degree[8] = {
4,10,10,4,0,14,0,0};
const int charTrendUp = 2;
byte rising[8] = {
0,0,4,14,31,0,0,0};
const int charTrendSteady = 3;
byte steady[8] = {
0,8,12,14,12,8,0,0};
const int charTrendDown = 4;
byte falling[8] = {
0,0,31,14,4,0,0,0};
const int charHappy = 5;
byte happy[8] = {
10,10,0,0,17,17,14,0};
const int charSad = 6;
byte sad[8] = {
10,10,0,0,14,17,17,0};
const int charCritical = 7;
byte critical[8] = {
17,10,17,0,14,17,17,14};
const int charNA = 8;
byte na[8] = {
31,17,14,4,10,21,31,0};
//0,14,21,23,17,14,0,0};
//9,13,11,9,6,9,15,9};
const int charClock0 = 9;
byte clock0[8] = {
const int charClock1 = 10;
byte clock1[8] = {
const int charClock2 = 11;
byte clock2[8] = {
const int charClock3 = 12;
byte clock3[8] = {
const int charClock4 = 13;
byte clock4[8] = {
const int charClock5 = 14;
byte clock5[8] = {
const int charClock6 = 15;
byte clock6[8] = {
lcd.begin(20,4);
lcd.createChar(1, degree);
lcd.createChar(2, rising);
lcd.createChar(3, steady);
lcd.createChar(4, falling);
lcd.createChar(5, happy);
lcd.createChar(6, sad);
lcd.createChar(7, critical);
lcd.createChar(8, na);
pinMode(backlightPin, OUTPUT);
pinMode(piezoPin, OUTPUT);
Serial.begin(115220);
attachInterrupt(0, silenceAlarm, LOW); // (dirty ?) way to register silence alarm button presses
fadeLCD(1,fadeLen); // a backlight fading effect looks cool
lcd.home();
lcd.print(" Fridge & Freezer ");
lcd.setCursor(0,1);
lcd.print(" Temperature Monitor");
lcd.setCursor(0,3);
lcd.print(" Initialising...");
if ((millis() - loopMillis) > (10000/timeFactor)) {
if (fridgeAlarmChanged + freezerAlarmChanged > 0) {
alarmAck = 0;
Serial.println("***** start loop *****");
lcd.home();
lcd.clear();
lcd.print("Fridge:");
lcd.setCursor(10,0);
// averaging the readings for improved accuracy
avgFridgeTemp = 0.3 * lm335(fridgeTempPin) + 0.7 * avgFridgeTemp;
lcd.print(avgFridgeTemp);
lcd.setCursor(16,0);
lcd.write(1);
lcd.setCursor(17,0);
lcd.print("C");
lcd.setCursor(0,2);
lcd.print("Freezer:");
lcd.setCursor(10,2);
avgFreezerTemp = 0.3 * lm335(freezerTempPin) + 0.7 * avgFreezerTemp;
lcd.print(avgFreezerTemp);
lcd.setCursor(16,2);
lcd.write(1);
lcd.setCursor(17,2);
lcd.print("C");
// the temperature gets stored every 5 mins (or less if realtime factor is >1)
storeTemp();
// calculate the temperature trend vs the stored samples
calcTrend(prevAvgFridgeTemp, avgFridgeTemp, 1);
prevAvgFridgeTemp = avgFridgeTemp;
calcTrend(prevAvgFreezerTemp, avgFreezerTemp, 2);
prevAvgFreezerTemp = avgFreezerTemp;
int prevFridgeAlarm2 = currFridgeAlarm;
int prevFreezerAlarm2 = currFreezerAlarm;
// checking if an alarm needs to be raised
checkAlarm(avgFridgeTemp,1);
checkAlarm(avgFreezerTemp,2);
soundAlarm();
loopMillis = millis();
** FUNCTIONS START HERE
// my function to fade the backlight in or out
// mode 1 = fade in
// mode 2 = fade out
// mode 3 = on without fading (for blinking on alarm)
// mode 4 = off without fading (for blinking on alarm)
void fadeLCD(byte mode, int duration) {
if (mode == 1) {
for (brightness = 0; brightness <= 255; brightness++) {
analogWrite(backlightPin, brightness);
if (brightness != 255) {
delay(duration/256);
if (mode == 0) {
for (brightness = 255; brightness >= 0; brightness--) {
if (brightness != 0) {
if (mode == 3) {
digitalWrite(backlightPin, HIGH);
if (mode == 4) {
digitalWrite(backlightPin, LOW);
// now unused because I replaced the thermistors with LM335s hoping to get
// improved accuracy (hum... not quite there yet)
double tempC(int sensorPin) {
int analogVal = analogRead(sensorPin);
double temp;
temp = log(((10240000/analogVal) - 10000));
temp = 1 / (0.001129148 + (0.000234125 * temp) + (0.0000000876741 * temp * temp * temp));
temp = temp - 273.15;
return temp;
// used to check if 5 minutes have passed since the last storage.
// if so, store a new value and print a '+' on the LCD to show when the
// value is stored
void storeTemp() {
if (millis() - lastStoreTempMillis > 300000/timeFactor) { // store a sample every 5 min
storedFridgeTemp[storedCnt] = avgFridgeTemp;
lcd.setCursor(19,1);
lcd.print("+");
Serial.print("storeTemp() avgFridgeTemp: ");
Serial.println(avgFridgeTemp);
storedFreezerTemp[storedCnt] = avgFreezerTemp;
lcd.setCursor(19,3);
lcd.print("+");
Serial.print("storeTemp() avgFreezerTemp: ");
Serial.println(avgFreezerTemp);
// I want to stop at 12 because I am averaging and trending only over
// the last 60 mins, overwriting the oldest value in the arrays
if (storedCnt > 12) {
storedCnt = 0;
storedCnt++;
lastStoreTempMillis = millis();
