Trying to compile "Factory Example" got error msg below.
Board selected is "ESP32 PICO Dev Kit"
Guidance, please
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chuck\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chuck\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chuck\Documents\Arduino\libraries -fqbn=esp32:esp32:pico32:UploadSpeed=921600,DebugLevel=none -ide-version=10803 -build-path C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215 -warnings=default -build-cache C:\Users\Chuck\AppData\Local\Temp\arduino_cache_590235 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -verbose C:\Users\Chuck\AppData\Local\Temp\arduino_modified_sketch_221631\FactoryTest.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chuck\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chuck\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chuck\Documents\Arduino\libraries -fqbn=esp32:esp32:pico32:UploadSpeed=921600,DebugLevel=none -ide-version=10803 -build-path C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215 -warnings=default -build-cache C:\Users\Chuck\AppData\Local\Temp\arduino_cache_590235 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -verbose C:\Users\Chuck\AppData\Local\Temp\arduino_modified_sketch_221631\FactoryTest.ino
Using board 'pico32' from platform in folder: C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1
Using core 'esp32' from platform in folder: C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1
Detecting libraries used...
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215\sketch\FactoryTest.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215\sketch\FactoryTest.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215\sketch\FactoryTest.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215\sketch\FactoryTest.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\FS\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215\sketch\FactoryTest.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\FS\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215\sketch\FactoryTest.ino.cpp" -o "C:\Users\Chuck\AppData\Local\Temp\arduino_build_590215\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src/M5Display.h:7:0,
from C:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src/M5StickCPlus.h:76,
from C:\Users\Chuck\AppData\Local\Temp\arduino_modified_sketch_221631\FactoryTest.ino:1:
C:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src/utility/In_eSPI.h:23:25: fatal error: hal/gpio_ll.h: No such file or directory
compilation terminated.
Multiple libraries were found for "FS.h"
Used: C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\FS
Not used: C:\Program Files (x86)\Arduino\libraries\FS
Using library M5StickC-Plus-master at version 0.1.0 in folder: C:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master
Using library Wire at version 1.0.1 in folder: C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI
Using library FS at version 1.0 in folder: C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\FS
exit status 1
Error compiling for board ESP32 Pico Kit.
kenb4
December 11, 2024, 9:36pm
2
Using the official "esp32" board, currently v3.0.7; under the Tools menu > Board > esp32 > a giant list, about in the middle, is M5StickCPlus, along with many other M5 boards. Try that one.
More importantly,
This is the second time in two days that I've seen a Library in the <sketchbook>\libraries directory with the name <name>-master with what looks like a branch name. The supposed version of this library
matches the latest version of the spelled-slightly-differently M5StickCPlus library. The spelling is the same as the repo name on GitHub: https://github.com/m5stack/M5StickC-Plus. And if you look at the problem line on the master branch, which as of today is from commit d7df7f3, 4 months ago
#define TFT_ESPI_VERSION "1.4.5"
//#define ESP32 //Just used to test ESP32 options
// Include hal/gpio to fix Espressif hiding GPIO from public use
#include "hal/gpio_ll.h"
// Include header file that defines the fonts loaded, the TFT drivers
// available and the pins to be used
#include "In_eSPI_Setup.h"
That does try to include that hal file. But that is not what the actual release version 0.1.0 has in the same place.
But the 0.1.0 release doesn't compile anyway, because of a stupid error with "smart quotes" instead of plain double-quotes in an #error message. Fixing that error leads to a less trivial set.
So how did you install that library?
Hope this is correct place to post this. Main question is, what is a GOOD source of info about these devices? What comes from M5 seems very weak.
Have no clue about the error below, Maybe need other library to use???
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chuck\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chuck\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chuck\Documents\Arduino\libraries -fqbn=esp32:esp32:pico32:UploadSpeed=921600,DebugLevel=none -ide-version=10803 -build-path C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138 -warnings=default -build-cache C:\Users\Chuck\AppData\Local\Temp\arduino_cache_590235 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -verbose C:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\examples\Basics\Display\Display.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chuck\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chuck\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chuck\Documents\Arduino\libraries -fqbn=esp32:esp32:pico32:UploadSpeed=921600,DebugLevel=none -ide-version=10803 -build-path C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138 -warnings=default -build-cache C:\Users\Chuck\AppData\Local\Temp\arduino_cache_590235 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -verbose C:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\examples\Basics\Display\Display.ino
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138\sketch\Display.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138\sketch\Display.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138\sketch\Display.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138\sketch\Display.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\FS\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138\sketch\Display.ino.cpp" -o "nul"
"C:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/config" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_trace" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/app_update" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/asio" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bootloader_support" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/bt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/coap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/console" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/driver" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-tls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_event" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_client" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_http_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_https_server" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ethernet" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/expat" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fatfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freemodbus" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/freertos" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/heap" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/idf_test" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/jsmn" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/json" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/libsodium" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/log" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/lwip" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mbedtls" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mdns" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/micro-ecc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/mqtt" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/newlib" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nghttp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/nvs_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/openssl" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protobuf-c" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/protocomm" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/pthread" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/sdmmc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/soc" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spi_flash" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/spiffs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcp_transport" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/ulp" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/unity" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/vfs" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wear_levelling" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp32-camera" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/esp-face" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10803 -DARDUINO_ESP32_PICO -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_PICO" -DARDUINO_VARIANT="pico32" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\cores\esp32" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\variants\pico32" "-IC:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI\src" "-IC:\Users\Chuck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\FS\src" "C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138\sketch\Display.ino.cpp" -o "C:\Users\Chuck\AppData\Local\Temp\arduino_build_870138\preproc\ctags_target_for_gcc_minus_e.cpp"
from C:\Users\Chuck\Documents\Arduino\libraries\M5StickC-Plus-master\examples\Basics\Display\Display.ino:13:
exit status 1
The error comes from the code You compile but did not post. Mind using code tags.
hal/gpio_ll.h sounds like a file from the STM32 HAL library.
Is this the file you're trying to compile? M5Stack/examples/Basics/Display/Display.ino at master · m5stack/M5Stack · GitHub
I'm fairly sure that I've built it before (for M5Stack Tough) with no problems.
pert
December 11, 2024, 10:21pm
7
I have merged your cross-posts @chuck659 .
Cross-posting is against the Arduino forum rules . The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum " guide . It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
