Hi, i'm new to the world of IMU. I want a sensor that accurately measure the inclination of an object. The IMU is the right choise? What is its sensivity in term of measuring inclination?
An IMU is intended for monitoring motion and general orientation. You can buy an inclinometer, or make one using just a 2D or 3d accelerometer. See this application note for how to do the latter.
There was a relative recent thread about using an accelerometer to measure incline.
Here's a quote from one of my posts in the thread.
****** Start of Quote ******
The acceleration from gravity will be
a = g * cosθ
So to find θ you use:
θ = acos(a / g)
****** End of Quote ******
I just now realized the above equation isn't a good one to use.
Let's say we're using a 12-bit accelerometer with a range of +/- 2g.
1 g should equal 1024 with this accelerometer. So the first reading one would read from the accelerometer as you tilted the sensor would be 1023. We can compute the able of this single bit difference with the equation:
acos(1023/1024) = 2.5323 degrees
The doesn't strike me as very precise.
However, if we use a different axis, and use the arcsine function we will get better precision.
If we use the axis which is zero when the sensor is level and 1024 when at 90 degrees, then our smallest detectable tilt will be:
asin(1/1024) = 0.05595 degrees.
This is much better than the 2.5323 degree figure we had earlier.
At 45 degree, we'll likely get the poorest performance from the sensor.
The closest reading to an exact 45 degree tilt would be 724. the difference in angles between 723 and 724 is:
asin(724/1024) - asin(723/1024) = 44.99388 - 44.91481 = 0.07907 degrees. This isn't as good as the 0.05595 degrees figure but it is still better than 2.5323 degrees.
So with a 3-axis accelerometer, if one axis returns a value larger than the g/(2-2) then you should use a different axis to compute the tilt. (2-2 is the square root of 2. sin(45) = 1 divided by the square root of 2. To me, one over the square root of 2 is an easier figure to remember than sin(45).)
Sorry for getting a bit technical. I still think this method is simpler than using the methods described in the app note to which jremington linked. Of course there a huge disadvantage to the method I just described, it assumes rotation in a single axis. The above method will allow you to calculate roll or pitch but if you're calculating roll, there can't be any pitch (and visa versa when calculating pitch).
Thank you very much, your answer is very useful and clear, this is exactly what I was looking for.
Megas112:
Good to hear.
I should add the "1024" figure was what 1g should be for a 12-bit +/-2g accelerometer. It would be a good idea to experimentally measure what 1g is in your area and with your sensor.
The complicated-appearing application note that I linked boils down to a very simple equation that works much better than either of the two single-axis possibilities discussed above.
For a 2D or 3D accelerometer, with Z down and tilting around the Y axis, the tilt angle in degrees is
float tilt_angle = atan2(ax, az)*180./3.14159.;
You may need to change the sign of ax, so that the sign of the angle produced agrees with your definition of a positive rotation angle.
For the most accurate results, you need to calibrate the accelerometer measurements so that "1 g" gives the same result regardless of which axis is pointing straight down.
jremington:
For a 2D or 3D accelerometer, with Z down and tilting around the Y axis, the tilt angle in degrees isfloat tilt_angle = atan2(ax, az)*180./3.14159.;
Thanks for the clarification.
I'm trying to get the possible accuracy/precision of various attitudes straight in my head. It seems like the above equation will favor some orientations over others.
I've got my BNO055 up and running and I'll need to see how the roll and pitch data compares with computing tilt from the raw acceleration values.
Thanks again for the app note link.
That is definitely true of sin() or cos().
The sin() function loses accuracy at close to 90 degrees, and cos() loses accuracy at close to 0 degrees. The atan2() function balances those two sources of inaccuracy out.
Here is a short C program to show the accuracy of atan2, acting on the simulated output of a 10 bit accelerometer tilted through 90 degrees. To conclude, the math has an inherent "sensitivity" of better than 0.1 degree, but consumer grade accelerometers are noisy, and you could expect perhaps 1 degree accuracy.
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
int main()
int i;
int x,z;
printf("tilt ax az diff\r\n");
for(i=0; i<91; i++) {
z = 1023.*cos(i*3.14159265/180.); //accelerometer az
x = 1023.*sin(i*3.14159265/180.); //accelerometer ax
printf("%3d %5d %5d %6.4f\r\n",i, x, z,((float)i) - 180.*atan2(x,z)/3.14159265);
return 0;
The result:
Columns are tilt angle (degrees), ax, az, difference between tilt angle and the result of atan2() in degrees.
tilt ax az diff
0 0 1023 0.0000
1 17 1022 0.0470
2 35 1022 0.0386
3 53 1021 0.0284
4 71 1020 0.0182
5 89 1019 0.0084
6 106 1017 0.0497
7 124 1015 0.0348
8 142 1013 0.0204
9 160 1010 -0.0018
10 177 1007 0.0310
11 195 1004 0.0087
12 212 1000 0.0305
13 230 996 -0.0030
14 247 992 0.0181
15 264 988 0.0397
16 281 983 0.0469
17 299 978 0.0002
18 316 972 -0.0095
19 333 967 -0.0019
20 349 961 0.0408
21 366 955 0.0309
22 383 948 0.0009
23 399 941 0.0222
24 416 934 -0.0080
25 432 927 0.0136
26 448 919 0.0114
27 464 911 0.0089
28 480 903 0.0066
29 495 894 0.0271
30 511 885 -0.0022
31 526 876 0.0170
32 542 867 -0.0113
33 557 857 -0.0215
34 572 848 -0.0008
35 586 837 0.0034
36 601 827 -0.0068
37 615 817 0.0292
38 629 806 0.0316
39 643 795 0.0339
40 657 783 0.0006
41 671 772 0.0038
42 684 760 0.0128
43 697 748 0.0214
44 710 735 -0.0088
45 723 723 -0.0000
46 735 710 0.0088
47 748 697 -0.0214
48 760 684 -0.0128
49 772 671 -0.0038
50 783 657 -0.0006
51 795 643 -0.0339
52 806 629 -0.0316
53 817 615 -0.0292
54 827 601 0.0068
55 837 586 -0.0034
56 848 572 0.0008
57 857 557 0.0215
58 867 542 0.0113
59 876 526 -0.0170
60 885 511 0.0022
61 894 495 -0.0271
62 903 480 -0.0066
63 911 464 -0.0089
64 919 448 -0.0114
65 927 432 -0.0136
66 934 416 0.0080
67 941 399 -0.0222
68 948 383 -0.0009
69 955 366 -0.0309
70 961 349 -0.0408
71 967 333 0.0019
72 972 316 0.0095
73 978 299 -0.0002
74 983 281 -0.0469
75 988 264 -0.0397
76 992 247 -0.0181
77 996 230 0.0030
78 1000 212 -0.0305
79 1004 195 -0.0087
80 1007 177 -0.0310
81 1010 160 0.0018
82 1013 142 -0.0204
83 1015 124 -0.0348
84 1017 106 -0.0497
85 1019 89 -0.0084
86 1020 71 -0.0182
87 1021 53 -0.0284
88 1022 35 -0.0386
89 1022 17 -0.0470
90 1023 0 -0.0000
Process returned 0 (0x0) execution time : 0.062 s
Press any key to continue.
jremington:
Shouldn't the sensitivity of the accelerometer be considered, such as ±2g ?
There's another approach here:
http://www.hobbytronics.co.uk/accelerometer-info but the atan2 function should be used.
