Hi I ve been using the mighty core on home brew Atmega1284P based system for some time now with no issues.
In my latest project however, I came across a very bizarre issue where I can only upload a sketch only once. Later times fail with a "programmer not responding message".
The only way around this is to burn the bootloader again, after which I can again upload a sketch just once!
I am using Arduino As ISP programmer (Mighty Core) as I always did.
Please see below output from :
A. Successful sketch upload
avrdude: Version 6.3-20201216
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\John\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 8.0
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: reading input file "C:\Users\John\AppData\Local\Temp\arduino_build_274511/Soldering_Station.ino.hex"
avrdude: writing flash (31540 bytes):
Writing | ################################################## | 100% 7.91s
avrdude: 31540 bytes of flash written
avrdude done. Thank you.
Subsequent failed sketch upload
Using Port : COM5
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4c
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
As mentioned earlier, this is the first time I am facing something like this!
Any ideas ?
