Modbus RTU RS485 Multislave
hello!
i am looking for some help with a project,the project I'm currently working on using
  • Arduino Mega (MASTER)
  • Arduino Nano (SLAVE) with SW420 (Vibration Sensor) and DHT11 (Temperature and Humidity Sensor) (2)
  • Max485 Ttl To Rs485 Converter Module (3)
pin configuration:
Master :
MASTER (Arduino Mega):
RS485 Module
  • Pin A,B Master to A,B Slave
  • VCC Ground to 5V and Ground
  • Pin DE,RE to Pin 2
  • Pin RO to Pin 11
  • Pin DI to Pin 12
SLAVE (Arduino Nano):
RS485 Module
  • Pin DE,RE to Pin D4
  • Pin RO to Pin D3
  • Pin DI to Pin D2
DHT11
  • Pin Data to Pin D8
SW420
  • Pin Data to Pin D9
Here I try to use the Modbus RTU Library.
I've been trying this for 3 weeks :frowning: But, the result is still the same still can't send data. What's wrong with my code or the microcontroller or what?
Here is the code and the result
MASTER
#include <ModbusRtu.h>
#define slaveNumber 5
#define delayCom 15
#define maxQuery 2*2//slaveNumer*2
#include <SoftwareSerial.h>
SoftwareSerial mySerial(11,12);
uint8_t u8state; //!< machine state
uint8_t u8query; //!< pointer to message query
uint16_t dataBus[slaveNumber*2];
uint16_t lastPrint=100;
int slaveID[slaveNumber] = {11,12,13,14,15};
 *  Modbus object declaration
 *  u8id : node id = 0 for master, = 1..247 for slave
 *  port : Serial1 port
 *  u8txenpin : 0 for RS-232 and USB-FTDI
 *               or any pin number > 1 for RS-485
Modbus master(0,mySerial,2); // ID, seriapNumber, enablePin
 * This is an structe which contains a query to an slave device
modbus_t telegram[slaveNumber*2];
unsigned long u32wait;
void init_modBus(){
  int num=0;
  int addr=0;
////SLAVE 1
  // Read 1 data from Slave 11
  telegram[num].u8id = slaveID[0]; // slave address
  telegram[num].u8fct = 3; // function code (this one is registers read)
  telegram[num].u16RegAdd = 0; // start address in slave
  telegram[num].u16CoilsNo = 2; // number of elements (coils or registers) to read
  telegram[num].au16reg = dataBus; // pointer to a memory array in the Arduino
  num+=1;
  addr+=2;
  // Write 1 data to Slave 11
  telegram[num].u8fct = 6; // function code (this one is write a multiple register)
  telegram[num].u16RegAdd = 2; // start address in slave
  telegram[num].u16CoilsNo = 1; // number of elements (coils or registers) to write
  telegram[num].au16reg = dataBus+2; // pointer to a memory array in the Arduino
  num+=1;
  addr+=1;
////SLAVE 2
//  // Read 1 data from Slave 2
//  telegram[num].u8id = slaveID[1]; // slave address
//  telegram[num].u8fct = 3; // function code (this one is registers read)
//  telegram[num].u16RegAdd = 0; // start address in slave
//  telegram[num].u16CoilsNo = 2; // number of elements (coils or registers) to read
//  telegram[num].au16reg = dataBus+3; // pointer to a memory array in the Arduino
//  num+=1;
//  addr+=2;
//  // Write 1 data to Slave 2
//  telegram[num].u8fct = 16; // function code (this one is write a multiple register)
//  telegram[num].u16RegAdd = 2; // start address in slave
//  telegram[num].u16CoilsNo = 1; // number of elements (coils or registers) to write
//  telegram[num].au16reg = dataBus+5; // pointer to a memory array in the Arduino
//  num+=1;
//  addr+=1;
  master.start();
  master.setTimeOut( 100 ); // if there is no answer in 100 ms, roll over
  u32wait = millis() + 40;
  u8state = u8query = 0;
void rtuState(){
  switch( u8state ) {
  case 0:
    if (millis() >= u32wait) u8state++; // wait state
  case 1:
    master.query( telegram[u8query] ); // send query (only once)
    u8state++;
    u8query++;
    if (u8query >= maxQuery)
      u8query = 0;
  case 2:
    master.poll(); // check incoming messages if communication in idle state
    if (master.getState() == COM_IDLE) {
      u8state = 0;
      u32wait = millis() + delayCom;  //delay for next state
void printData(){
  if (millis() - lastPrint>200){
    Serial.print(dataBus[0]); Serial.print(":");
    Serial.print(dataBus[1]); Serial.print(":");
    Serial.print(dataBus[2]); Serial.print("\t:\t");
  Serial.begin (9600); //baud rate of Serial PC
  mySerial.begin(19200); // baud-rate of RS485
  init_modBus();
  rtuState();
  printData();
SLAVE
//SLAVE MENGIRIM DATA DETAK JANTUNG//
SoftwareSerial mySerial(2, 3);
#include "DHT.h"
#define slaveID 11
//#define trigPin 9
//#define echoPin 10//CARI EN PIN NOMOR BERAPA
#define DHTPIN 8
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
int vs=9; //pin vibration
uint16_t suhu =0;
uint16_t lembab=0;
uint16_t getar=0;
unsigned long lastPrint=0;
// data array for modbus network sharing
uint16_t au16data[4] = {
  slaveID, 225, 8888,9999};
Modbus slave(slaveID,mySerial,4); // this is slave @1 and RS-232 or USB-FTDI
  mySerial.begin( 19200 ); // baud-rate at 19200
  slave.start();
  delay(10);
  dht.begin();
  slave.poll( au16data, 4 );
    Serial.print(au16data[0]); Serial.print(":");
    Serial.print(au16data[1]); Serial.print(":");
    Serial.print(au16data[2]); Serial.println();
    lastPrint = millis();
  suhu = dht.readHumidity();
  au16data[1] = suhu;
Result
Are there any suggestions for what I can do and references I should study?
What basic testing did you do on your setup?
I would forget Modbus for now and simply print a few characters from the master and see if your slaves can receive them. Then i would make each slave the mater and repeat the process checking out the low level basics first.
I would highly recommend you get an RS485-USB dongle too so you can look at the actual data on you RS485 bus.
And, by Arduino Mega, did you mean a MEGA2560 based board?
A SoftwareSerial is not really useful in your project.
A Mega has enough hardware Serial ports, no need to use SoftwareSerial on your master.
Previously I used "Serial1" and I tried to use SoftwareSerial but still can't
Try a Mega and hardware Serial for both master and slave. If that doesn't work for you, too, then start searching for other problems in your code and hardware.
