Hi all,
In my project I'm using an RGB 12 V strip of leds.
Each color is driven by a PWM Arduino Pin, through a Mosfet IRF 530.
So I built a little shield with 3 Mosfet,
something like this:
Now, I need to miniaturize as such as possible the shield, so I'm wondering if it is possible to replace the Mosfet with some other TINY component. My knowledge about electronic props is very poor.
Ahahahahah! You are right!
The strip is about 1 meter long.
Given that I never use white light, I think I'm reasonably below 1 ampere (I'll check!).
About "smaller Mosfet", do you have any advice?
As I said, my Knowledge about electronic props is poor
(I always used IRF530)
Thanks!
What matters is the per-channel current, since each channel has it's own fet (right?)
1m is probably under an amp per channel - You can easily get SOT-23 MOSFETs that will handle that; you don't even need to look at the top of the range. SI2302's can be had for like 3 cents each on ebay, and they should be able to handle ~1A no problem. You can also search for SOT-23 n-channel mosfets on digikey and use their sorting/filters to find many many other candidates.
No, it's not. I don't know why it's so popular - I think it's just because they recognize it because all the chinese mosfet modules use that or the 510. It kinda works at 5v on gate, though.
valerio_sperati:
Thanks a lot
DPAK or DPAK2 packages are hand-solderable but a lot more compact than TO220.
There are many smaller (but harder to solder) package sizes too.
Pick a logic-level MOSFET with 20 or 30V rating and Rds(on) <= 50 milliohms. Find a
decent supplier that stocks 100,000+ component lines and you'll have a wide choice of
device. That depends on which territory you are in.
That Jerome guy has his FETs wired wrong, as several pointed out in the Comments there - some have the Gate pulldown on the Gate and some on the Source.
(He never addressed the matter.)
Depending on the current required, you may be able to use FET drivers (MIC4427 et al.) instead.
Ok, thanks a lot for your informations.
As I understand, the Mosfet I used till now (IRF 530) is a "TO-220" package,
while the suggested SOT-23 is a "DDPACK" package.
I'll try with the SOT-23.
I just found a few IRLM6401 P-channel Mosfets. Would they be suitable in this application? I get the feeling they're designed for 1.8v logic level (from the datasheet), but I'm still having a hard time reading transistor datasheets. Here's a typical datasheet for these so-23 parts :
That device will work at 5V. Just note that the gate is very sensitive to over-voltage (+/-8V will
trash it), so it will also be very static-sensitive, use proper handling precautions and make sure
the 5V supply is decent.
You'll note the on-resistance is a lot higher when driven from 1.8V, at 5V drive you get 50 milliohm,
but at 1.8V drive that becomes 125 milliohm
