Hi everyone!![]()
I've been working on a research project for my program. I wanted to measure the air quality of the surroundings of our region. I plan to measure Carbon Monoxide levels and Particulate matter.
My problem now is how to measure the CO levels. I am using the MQ7 module which is the MQ7 sensor itself and it's circuit board which includes a comparator circuit for the digital output. I don't need the digital output though, I need the analog outputs to compare the readings of different locations in our regions. I saw the datasheet for the MQ7 sensor itself and it was more complicated than I thought.
I needed to activate the sensor's heater by plugging it to 5 volts for 60 seconds, then pullung it down to 1.4 volts for 90 seconds. The measuring window is the last few seconds before pulling it down to 1.4 volts. I was able to make a circuit using a single MOSFET that could make the arduino switch the MQ7 module power from 5 to 1.4v. But the problem is, whenever it pulls down to 1.4v the module LED indicator switches off. There is no enough power to sustain the module; and therefore I cannot measure it.
How can I properly use the MQ7 module for this project? Looking forward to your kind responses😊. Thank you very much
Here is my schematic. I apologize for the poor quality.
