I have 2 monitors and have recently turned one so that it is Portrait. Every since I've done this I can not see the IDE window. I can see it on the task bar but I can not max the window on the desktop so I can use it! Does anyone have and clue why? I'm using the latest Windows 11.
Regards
Mark
P.S. This seems to be a similar issue to the one labelled " Arduino IDE startup issues". It differs insomuch that the IDE was working fine before I turned the monitor through 90 degrees. And yes I've uninstalled and reinstalled the IDE Nightly build! Twice! (Yeah Yeah, first sign of Madness! I know!)
Addendum:
The monitors are connected to an HDMI and a Mini Graphical port. I swapped the connections and then make the HDMI, the Vertical Monitor "My Main Monitor". It now all seems to work fine!
