I got into sending power to the dc motors in order to spin the wheels.
Activating the M2 ports of the carrier indeed spins the left wheel but when I do the same to the M1 ports in order to spin the right wheel, it starts a long beep.
I couldn't use the '1669805216-simulink-rover-control.slx' file as it throws me an error regarding the name. Regarding that I found a topic already made here but with no replies:
Also if I stop the left wheel before starting the right wheel, the same thing happens.
I redid the wiring following the video again to make sure and same thing happens.
If the "diagram" I made looks too horrible, I placed a little snip from the video that makes the pins on the carrier more distinct with their names and also the color coding being the same.
Thanks! The colours don't tell much without the datasheet.
Is that the M1 cableing You show? The running motor?
I guess the other motor is connected to the socket down in the picture. Check the symbols printed on the board for the functioning motor and compare with the troubleing motor.
No chance to read and check from the picture. Don't assume anything.
Schematics shows the names, the labels, of the places were the cable is fitted. Your picture show the positions and that's not helping us.
