I want to work of this code to somehow make an alarm clock, I have all the pieces but have no idea where to start.. Please if anyone can help
Thanks
The Code:
// Include Libraries
#include "Arduino.h"
#include "Buzzer.h"
#include "LiquidCrystal_PCF8574.h"
#include "Button.h"
#include "Wire.h"
#include "RTClib.h"
// Pin Definitions
#define BUZZER_PIN_SIG 2
#define PUSHBUTTON_1_PIN_2 3
#define PUSHBUTTON_2_PIN_2 4
#define PUSHBUTTON_3_PIN_2 5
#define PUSHBUTTON_4_PIN_2 6
// Global variables and defines
// There are several different versions of the LCD I2C adapter, each might have a different address.
// Try the given addresses by Un/commenting the following rows until LCD works follow the serial monitor prints.
// To find your LCD address go to: Arduino Playground - I2cScanner and run example.
#define LCD_ADDRESS 0x3F
//#define LCD_ADDRESS 0x27
// Define LCD characteristics
#define LCD_ROWS 2
#define LCD_COLUMNS 16
#define SCROLL_DELAY 150
#define BACKLIGHT 255
// object initialization
Buzzer buzzer(BUZZER_PIN_SIG);
LiquidCrystal_PCF8574 lcdI2C;
Button pushButton_1(PUSHBUTTON_1_PIN_2);
Button pushButton_2(PUSHBUTTON_2_PIN_2);
Button pushButton_3(PUSHBUTTON_3_PIN_2);
Button pushButton_4(PUSHBUTTON_4_PIN_2);
RTC_DS3231 rtcDS;
// define vars for testing menu
const int timeout = 10000; //define timeout of 10 sec
char menuOption = 0;
long time0;
// Setup the essentials for your circuit to work. It runs first every time your circuit is powered with electricity.
// Setup Serial which is useful for debugging
// Use the Serial Monitor to view printed messages
while (!Serial) ; // wait for serial port to connect. Needed for native USB
Serial.println("start");
// initialize the lcd
lcdI2C.begin(LCD_COLUMNS, LCD_ROWS, LCD_ADDRESS, BACKLIGHT);
pushButton_1.init();
pushButton_2.init();
pushButton_3.init();
pushButton_4.init();
if (! rtcDS.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (rtcDS.lostPower()) {
Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
rtcDS.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtcDS.adjust(DateTime(2014, 1, 21, 3, 0, 0));
menuOption = menu();
// Main logic of your circuit. It defines the interaction between the components you selected. After setup, it runs over and over again, in an eternal loop.
if(menuOption == '1') {
// Buzzer - Test Code
// The buzzer will turn on and off for 500ms (0.5 sec)
buzzer.on(); // 1. turns on
delay(500); // 2. waits 500 milliseconds (0.5 sec). Change the value in the brackets (500) for a longer or shorter delay in milliseconds.
buzzer.off(); // 3. turns off.
delay(500); // 4. waits 500 milliseconds (0.5 sec). Change the value in the brackets (500) for a longer or shorter delay in milliseconds.
else if(menuOption == '2') {
// LCD 16x2 I2C - Test Code
// The LCD Screen will display the text of your choice.
lcdI2C.clear(); // Clear LCD screen.
lcdI2C.print(" Circuito.io "); // Print print String to LCD on first line
lcdI2C.selectLine(2); // Set cursor at the begining of line 2
lcdI2C.print(" Rocks! "); // Print print String to LCD on second line
else if(menuOption == '3') {
// Mini Pushbutton Switch #1 - Test Code
//Read pushbutton state.
//if button is pressed function will return HIGH (1). if not function will return LOW (0).
//for debounce funtionality try also pushButton_1.onPress(), .onRelease() and .onChange().
//if debounce is not working properly try changing 'debounceDelay' variable in Button.h
bool pushButton_1Val = pushButton_1.read();
Serial.print(F("Val: ")); Serial.println(pushButton_1Val);
else if(menuOption == '4') {
// Mini Pushbutton Switch #2 - Test Code
//for debounce funtionality try also pushButton_2.onPress(), .onRelease() and .onChange().
bool pushButton_2Val = pushButton_2.read();
Serial.print(F("Val: ")); Serial.println(pushButton_2Val);
else if(menuOption == '5') {
// Mini Pushbutton Switch #3 - Test Code
//for debounce funtionality try also pushButton_3.onPress(), .onRelease() and .onChange().
bool pushButton_3Val = pushButton_3.read();
Serial.print(F("Val: ")); Serial.println(pushButton_3Val);
else if(menuOption == '6') {
// Mini Pushbutton Switch #4 - Test Code
//for debounce funtionality try also pushButton_4.onPress(), .onRelease() and .onChange().
bool pushButton_4Val = pushButton_4.read();
Serial.print(F("Val: ")); Serial.println(pushButton_4Val);
else if(menuOption == '7') {
// RTC - Real Time Clock - Test Code
//This will display the time and date of the RTC. see RTC.h for more functions such as rtcDS.hour(), rtcDS.month() etc.
DateTime now = rtcDS.now();
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print('/');
Serial.print(now.year(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
if (millis() - time0 > timeout)
// Menu function for selecting the components to be tested
// Follow serial monitor for instrcutions
char menu()
Serial.println(F("\nWhich component would you like to test?"));
Serial.println(F("(1) Buzzer"));
Serial.println(F("(2) LCD 16x2 I2C"));
Serial.println(F("(3) Mini Pushbutton Switch #1"));
Serial.println(F("(4) Mini Pushbutton Switch #2"));
Serial.println(F("(5) Mini Pushbutton Switch #3"));
Serial.println(F("(6) Mini Pushbutton Switch #4"));
Serial.println(F("(7) RTC - Real Time Clock"));
Serial.println(F("(menu) send anything else or press on board reset button\n"));
while (!Serial.available());
// Read data from serial monitor if received
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if(c == '1')
Serial.println(F("Now Testing Buzzer"));
else if(c == '2')
Serial.println(F("Now Testing LCD 16x2 I2C"));
else if(c == '3')
Serial.println(F("Now Testing Mini Pushbutton Switch #1"));
else if(c == '4')
Serial.println(F("Now Testing Mini Pushbutton Switch #2"));
else if(c == '5')
Serial.println(F("Now Testing Mini Pushbutton Switch #3"));
else if(c == '6')
Serial.println(F("Now Testing Mini Pushbutton Switch #4"));
else if(c == '7')
Serial.println(F("Now Testing RTC - Real Time Clock"));
Serial.println(F("illegal input!"));
return 0;
time0 = millis();
return c;
