Hi
Let's start from the components list:
- DC-DC converter module Step-down 3-40V - adjustable 1.5-35V LM2596 (to reduce the input 5V to 4V)
- Grove - I2C Motor Driver (TB6612FNG)
- NEMA 17 Stepper Motor 42HM48-1206 400 steps 4,0V / 1,2A / 0,31Nm
- MB102 Power Supply Adapter or direct USB connector
- Arduino Micro + 2x16 display
The goal is to power the motor correctly - maybe I took wrong components.
I thought that the initial setup was ok - 5V 2.4A powerbank, step-down converter and 4V set as the otuput which powered the motor driver.
Arduino powered from the PC.
Results - the motor is working, I checked different speeds - looks ok. For micro steps the min/max speed is limited but it's ok. On half steps it works for minimal possible speed which I can set - good.
Next step - trying to make it more portable. Small change in Arduino power supplying - no micro USB usage, the VIN pin was for 7-12V input - so I connected the 5V from the powerbank to the 5V pin.
It's working ok - time to start the motor - and the issue starts. Looks like the display (and built-in LED) is blinking a little bit for very slow motor speed. For faster values I see no blinking but the light is a little bit darker.
I connected the Arduino to separate powerbank (no more blinking) but I also checked the voltages for the motor.
Results:
- motor stopped - 5V on the converter input, 4V on the output
- motor started - 4.5V on the converter input, 3V on the output
Looks like the 2.4A powerbank is not enough but the converter takes up to 0.35A when the motor is running on lowest speed and 0.1A for higher speed (it's the motor only, no extra load etc.).
I checked also the travel charger AC 230V to 5V 2.4A - similar results.
I changed the power supply to MB102 Power Supply Adapter + AC 230V to 9V, 2A power supply.
Results (measured on the step-down converter input):
- motor stopped - 5.05V
- motor started - 4.95V and 0.35A-0.1A for low/high motor speed
In this configuration looks like the voltage drop is very small - I suppose it should be ok.
Now the question - what's wrong with the powerbank? Should I just use something better - like 4A or more? I didn't see the higher values than 0.35A - is it something wrong with my measurement approach (or the results inerpretation)? Or maybe it's because of the simple multimeter usage - which doesn't show some very short peaks which are much bigger than 0.35A? Unfortunately I don't have the oscilloscope (sounds like nice reason to buy a new toy).
