No matching function for call to 'MCP_CAN::readMsgBuf(uint8_t*, uint8_t [8])'
Hello Arduino Community,
I did compile a code for CAN-Bus communication and get that error below. Any hints available what I did wrong?
Compilation error: no matching function for call to 'MCP_CAN::readMsgBuf(uint8_t*, uint8_t [8])'
 *  TurboKitten Digital Dashboard
 *  This is an Arduino sketch which receives data from a MegaSquirt via CAN BUS
 *  and displays it on a Nextion LCD panel.
 *  Copyright (C) 2015-2016  Chris "Kai" Frederick
 *  This program is free software; you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation; either version 2 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License along
 *  with this program; if not, see <http://www.gnu.org/licenses/>.
#include <mcp_can.h>
#include <SPI.h>
#include <SoftwareSerial.h>
#include "nextion.cpp"
#include "tick.cpp"
#define PIN_LCD_RX 5
#define PIN_LCD_TX 4
#define PIN_CAN_CS 9   // chip select
#define PIN_CAN_INT 2  // interrupt
//#define DEBUG_CAN_ID 1521           // If defined, dump frames sent to this CAN id
#define HOUSEKEEPING_INTERVAL_MS 200  // How frequently to run watchdog, display refresh, etc
#define HOUSEKEEPING_PHASE_MS 100     // When to start first housekeeping run
#define ADC_PAGE_1_INTERVAL_MS 50  // How frequently to transmit ADC Page 1 data
#define ADC_PAGE_1_PHASE_MS 15     // When to start first ADC Page 1 transmission
#define ADC_PAGE_1_ID 0x20         // Destination CAN ID for Page 1
#define ADC_PAGE_2_INTERVAL_MS 50  // How frequently to transmit ADC Page 2 data
#define ADC_PAGE_2_PHASE_MS 25     // When to start first ADC Page 2 transmission
#define ADC_PAGE_2_ID 0x21         // Destination CAN ID for Page 2
MCP_CAN CAN0(PIN_CAN_CS);
SoftwareSerial lcdstream(PIN_LCD_RX, PIN_LCD_TX);
 *  Set up the gauges.
 *  v0,v1,v2 are guages on the left top; l0,l1,l2 are labels to the right of v0,v1,v2;
 *  v3,v4,v5,v6 are gauges on the top right; l3,l4,l5,l6 are labels to the right of v3,v4,v5,v6;
 *  b0,b1,b2,b3 are along the bottom;
 *  warn is a full-width line of text.
 *  Redlines / yellowlines are specified in raw, unscaled units.
//                                   id,  lid, suffix, scale, decimals, red_low, yellow_low, yellow_high, red_high, ref
NextionObject map_g(&lcdstream, "v0", "l0", "", 10, 0, 0, 0, 2600, 2800, 20),
  afr_g(&lcdstream, "v1", "l1", "", 10, 1, 100, 105, 150, 155, 100),
  rpm_g(&lcdstream, "v2", "l2", "", 1, 0, 0, 0, 6500, 7000, 100),
  vss_g(&lcdstream, "v3", "l3", "", 1, 0, -32768, -32768, 32767, 32767, 200),
  art_g(&lcdstream, "v4", "l4", "", 10, 1, -32768, -32768, 32767, 32767, 200),
  spk_g(&lcdstream, "v5", "l5", "", 10, 1, -32768, -32768, 32767, 32767, 50),
  egt_g(&lcdstream, "v6", "l6", "", 1, 0, 500, 700, 1600, 1800, 100),
  clt_g(&lcdstream, "b0", "", "cltF", 10, 0, 600, 1500, 2000, 2200, 1010),
  mat_g(&lcdstream, "b1", "", "matF", 10, 0, 200, 400, 1400, 1600, 200),
  oit_g(&lcdstream, "b2", "", "oilF", 1, 0, -32768, -32768, 32767, 32767, 1000),
  bat_g(&lcdstream, "b3", "", "v", 10, 1, 120, 130, 147, 150, 500),
  warn_g(&lcdstream, "warn", "", "", 0, 0, 0, 0, 0, 0, 50);
 *  Receive and process an incoming CAN frame.  Any known ids will be
 *  decoded and sent to the LCD.
void handleCANFrame(void) {
  uint8_t len,    // Number of bytes received
    rxBuf[8];     // CAN BUS receive buffer
  uint32_t rxId,  // CAN BUS device/arbitration ID
    val;          // Temp buffer to decode a particular value
  CAN0.readMsgBuf(&len, rxBuf);
  rxId = CAN0.getCanId();
#ifdef DEBUG_CAN_ID
  if (rxId == DEBUG_CAN_ID) {
    Serial.print(rxId);
    Serial.print(" ");
    uint8_t i;
    for (i = 0; i < 8; i++) {
      Serial.print(rxBuf[i], HEX);
      Serial.print(" ");
    Serial.println(" !");
#endif
  switch (rxId) {
    case 1520:
      rpm_g.val(ntohs(*(int16_t *)&rxBuf[6]));  // RPM 1rpm
    case 1521:
      spk_g.val((int16_t)ntohs(*(int16_t *)&rxBuf[0]));  // SPK total advance 0.1deg
      art_g.val(rxBuf[4]);                               // AFR target 0.1 ratio
      // Update the red/yellow lines for the AFR gauge.  Note that this frame doesn't update
      // the measured AFR, so there may be a slight flicker if the target changes rapidly.
      afr_g.update_afr_target(rxBuf[4]);
    case 1522:
      map_g.val(ntohs(*(uint16_t *)&rxBuf[2]));          // MAP 0.1 kPa
      mat_g.val((int16_t)ntohs(*(int16_t *)&rxBuf[4]));  // MAT 0.1degF
      clt_g.val((int16_t)ntohs(*(int16_t *)&rxBuf[6]));  // CLT 0.1 degF, cast for sign
    case 1523:
      // TPS offset 0 int16_t 0.1pct
      bat_g.val(ntohs(*(uint16_t *)&rxBuf[2]));  // BAT 0.1 volt
      afr_g.val(rxBuf[5]);                       // AFR 0.1 ratio
    case 1524:
      // Knock input offset 0 uin16_t 0.1pct
    case 1542:
      egt_g.val((int16_t)ntohs(*(int16_t *)&rxBuf[0]));  // EGT 0.1 degF  (or degC ?), cast for sign
    case 1562:
      // FIXME: suspicious inline constant conversion factor
      // FIXME: floats are evil
      vss_g.val(ntohs(*(uint16_t *)&rxBuf[0]) / 4.4);  // VSS unknown unit
    case 1571:
      // Ports: A, B, EH, K, MJ, P, T, CEL_err
    case 1572:
      val = ntohs(*(uint16_t *)&rxBuf[2]);  // Knock retard 0.1deg
      if (val > 0)
        warn_g.txt("KNOCK");
        warn_g.txt("");
  CAN0.begin(CAN_500KBPS);  // Assumes module with 16MHz clock - use CAN_1000KBPS for 8MHz clock.
  lcdstream.begin(115200);
  lcdstream.print(EOC);  // Terminate any partial command sent before boot
  warn_g.pco("RED");
  Serial.println("Boot");
// Refresh all the label values.
void refresh_labels() {
  map_g.label("MAP kPa");
  afr_g.label("AFR");
  rpm_g.label("RPM");
  art_g.label("AFR trgt");
  vss_g.label("VSS mph");
  spk_g.label("Advance");
  egt_g.label("EGT degF");
// Check the watchdog on all gauges.
void check_watchdogs() {
  map_g.watchdog();
  afr_g.watchdog();
  rpm_g.watchdog();
  art_g.watchdog();
  vss_g.watchdog();
  spk_g.watchdog();
  egt_g.watchdog();
  clt_g.watchdog();
  mat_g.watchdog();
  oit_g.watchdog();
  bat_g.watchdog();
  warn_g.watchdog();
  lcdstream.print("clk.val=0" EOC);  // Reset the Nextion watchdog
// Sample ADCs and transmit them to CAN
void can_send_adc(
  uint16_t can_id,  // CAN ID to send sample data
  uint8_t a,        // Analog pin ID
  uint8_t b,        // Analog pin ID
  uint8_t c,        // Analog pin ID
  uint8_t d         // Analog pin ID
  uint16_t samples[4];
  samples[0] = htons(analogRead(a));
  samples[1] = htons(analogRead(b));
  samples[2] = htons(analogRead(c));
  samples[3] = htons(analogRead(d));
  CAN0.sendMsgBuf(can_id, 0, 8, (byte *)&samples);
  static Tick housekeeping_tick(HOUSEKEEPING_INTERVAL_MS, HOUSEKEEPING_PHASE_MS),
    adc_page_1_tick(ADC_PAGE_1_INTERVAL_MS, ADC_PAGE_1_PHASE_MS),
    adc_page_2_tick(ADC_PAGE_2_INTERVAL_MS, ADC_PAGE_2_PHASE_MS);
  if (housekeeping_tick.tocked()) {
    refresh_labels();
    check_watchdogs();
  if (adc_page_1_tick.tocked()) {
    can_send_adc(ADC_PAGE_1_ID, A0, A1, A2, A3);
  if (adc_page_2_tick.tocked()) {
    can_send_adc(ADC_PAGE_2_ID, A4, A5, A6, A7);  // Note that A6 and A7 don't physically exist on DIP28-based AVRs
  if (!digitalRead(PIN_CAN_INT)) {  // CAN frame waiting in receive buffer
    handleCANFrame();
it looks like there should be three parameters not two, e.g.
INT8U readMsgBuf(INT32U *id, INT8U *len, INT8U *buf);
Well, I did just download the code from that source and try to compiling.
dash-kitten
/Users/...../Downloads/dash-kitten-master/dash-kitten/dash-kitten.ino: In function 'void handleCANFrame()':
/Users/....../Downloads/dash-kitten-master/dash-kitten/dash-kitten.ino:81:30: error: no matching function for call to 'MCP_CAN::readMsgBuf(uint8_t*, uint8_t [8])'
In file included from /Users/.....Downloads/dash-kitten-master/dash-kitten/dash-kitten.ino:24:0:
/Users/........../Documents/Arduino/libraries/mcp_can/mcp_can.h:119:11: note: candidate: byte MCP_CAN::readMsgBuf(long unsigned int*, byte*, byte*, byte*)
     INT8U readMsgBuf(INT32U *id, INT8U *ext, INT8U *len, INT8U *buf);   // Read message from receive buffer
/Users/........./Documents/Arduino/libraries/mcp_can/mcp_can.h:119:11: note:   candidate expects 4 arguments, 2 provided
/Users/........./Documents/Arduino/libraries/mcp_can/mcp_can.h:120:11: note: candidate: byte MCP_CAN::readMsgBuf(long unsigned int*, byte*, byte*)
     INT8U readMsgBuf(INT32U *id, INT8U *len, INT8U *buf);               // Read message from receive buffer
/Users/........../Documents/Arduino/libraries/mcp_can/mcp_can.h:120:11: note:   candidate expects 3 arguments, 2 provided
/Users/........../Downloads/dash-kitten-master/dash-kitten/dash-kitten.ino:82:15: error: 'class MCP_CAN' has no member named 'getCanId'; did you mean 'getGPI'?
               getGPI
/Users/........../Downloads/dash-kitten-master/dash-kitten/dash-kitten.ino: In function 'void setup()':
/Users/........../Downloads/dash-kitten-master/dash-kitten/dash-kitten.ino:151:25: error: no matching function for call to 'MCP_CAN::begin(int)'
In file included from /Users/..........Downloads/dash-kitten-master/dash-kitten/dash-kitten.ino:24:0:
/Users/........../Documents/Arduino/libraries/mcp_can/mcp_can.h:110:11: note: candidate: byte MCP_CAN::begin(byte, byte, byte)
     INT8U begin(INT8U idmodeset, INT8U speedset, INT8U clockset);       // Initialize controller parameters
/Users/..........Documents/Arduino/libraries/mcp_can/mcp_can.h:110:11: note:   candidate expects 3 arguments, 1 provided
exit status 1
Open up 'mcp_can.h" and look at the code. There are two overloads for the function readMsgBuf(). One of them takes 3 arguments, the other 4 arguments:
@horace already pointed this out to you.
Your function call is only supplying 2 arguments:
It seems fairly obvious that isn't going to work.
Thanks both for your support and I will check the details again.
