Hello,
I am using a Jay Consystem CAN bus shield for the arduino uno. I am also using the BUS library found here: GitHub - coryjfowler/MCP_CAN_lib: MCP_CAN Library. I'm using this example code that I found in a book:
#include "mcp_can.h"
#include "mcp_can.cpp"
#include "mcp_can_dfs.h"
#include <SPI.h>
MCP_CAN CAN0(10);
unsigned char stmp[8] = {0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37};
if (CAN0.begin(CAN_250KBPS) == CAN_OK)
Serial.print("CAN Init OK.");
Serial.print("CAN Init Failed.");
CAN0.sendMsgBuf(0x1FF, CAN_EXTID, 8, stmp);
I make sure to include the three files that were needed for the projects. mcp_can.cpp, mcp_can.h, and mcp_can_dfs.h. Now from there, I verify the code and get the following error:
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\David\Documents\Arduino\CAAN_TEST\CAAN_TEST.ino: In function 'void setup()':
CAAN_TEST:13: error: no matching function for call to 'MCP_CAN::begin(int)'
C:\Users\David\Documents\Arduino\CAAN_TEST\CAAN_TEST.ino:13:29: note: candidate is:
In file included from C:\Users\David\Documents\Arduino\CAAN_TEST\CAAN_TEST.ino:3:0:
sketch\mcp_can.cpp:740:7: note: byte MCP_CAN::begin(byte, byte, byte)
INT8U MCP_CAN::begin(INT8U idmodeset, INT8U speedset, INT8U clockset)
sketch\mcp_can.cpp:740:7: note: candidate expects 3 arguments, 1 provided
exit status 1
option enabled in File -> Preferences.
Can anyone please help. Thank you very much
