No output from MIDI shield
Hello teacher, I purchased a device like the one discussed at:
I connected it to the UNO. When my MIDI output port is connected to an LED and a 220-ohm resistor, it flashes with the TX output signal of the UNO. However, there is no signal when I connect the MIDI output to an external device. I measured the MIDI 4th and 5th pins with a multimeter and found only 50mV. I don't know where the problem is, but I saw the discussion at MIDI Shield breakout box - free pins? and it seems like a ray of hope. Please help me, teacher.
The Uno R3 alone can't be used to generate MIDI.
We need much more information as to what you have in terms of code and schematic.
You might want to look at this How to get the best out of this forum before you proceed any further.
We only know what you tell us, and without knowing what you have, we don't stand a chance.
