No puedo compilar arduinoFFT
basandome en este proyecto de un Audio Spectrum Analyzer with ESP32 el codigo que proporciona funciona correctamente en el video, segui los pasos, descargue las libreias necesarias y aun asi aparece este error:
'arduinoFFT' does not name a type; did you mean 'ArduinoFFT'?
estuve probando con otros proyectos con el mismo tema de hacer un espectrum con un esp32 y aparece siempre ese error en todos los codigos, agradeceria que me ayudaran
adjunto el link del proyecto:
https://community.element14.com/challenges-projects/element14-presents/project-videos/w/documents/27805/making-a-wifi-connected-audio-spectrum-analyzer-with-esp32----episode-570
    Project:         Webspector - WebServer based Spectrum Analyzer
    Target Platform: ESP32        *
    Version: 1.1
    Hardware setup: See github
    Mark Donners
    The Electronic Engineer
    Website:   www.theelectronicengineer.nl
    facebook:  https://www.facebook.com/TheelectronicEngineer
    youtube:   https://www.youtube.com/channel/UCm5wy-2RoXGjG2F9wpDFF3w
    github:    https://github.com/donnersm
 *   This sketch consists of 2 files; this one and the Settings.h file. Make sure both are in the same directory!
 *   All settings that you can change are in the Settings.h file
 *   Do not change settings below
#define VERSION     "V1.1"
//included files
#include "Settings.h"
//general libaries
#include <arduinoFFT.h>                                 //libary for FFT analysis
#include <EasyButton.h>                                 //libary for handling buttons
//libaries for webinterface
#include <WiFi.h>
#include <WebServer.h>
#include <WebSocketsServer.h>
#include <Ticker.h>
#include <WiFiManager.h>                                //The magic setup for wifi! If you need to setup your WIFI, hold the mode button during boot up.
//Driver for I2S ADC Conversion
#include <driver/i2s.h>
#include <driver/adc.h>
//Variables and stuff that don't need changing          //*
const i2s_port_t I2S_PORT = I2S_NUM_0;                  //*
#define ADC_INPUT ADC1_CHANNEL_0                        //*
#define ARRAYSIZE(a)    (sizeof(a)/sizeof(a[0]))        //*
uint16_t offset = (int)ADC_INPUT * 0x1000 + 0xFFF;      //*
double vReal[SAMPLEBLOCK];                              //*
double vImag[SAMPLEBLOCK];                              //*
int16_t samples[SAMPLEBLOCK];                           //*
byte peak[65];                                          //*
int oldBarHeights[65];                                  //*
volatile float FreqBins[65];                            //*
float FreqBinsOld[65];                                  //*
float FreqBinsNew[65];                                  //*
// below is is function that is needed when changing the number of bands during runtime, do not change
void SetNumberofBands(int bandnumber) {
  switch (bandnumber)
    case 8:
      for (int x = 0; x < bandnumber; x++)
        BandCutoffTable[x] = BandCutoffTable8[x];
        labels[x] = labels8[x];
    case 16:
        BandCutoffTable[x] = BandCutoffTable16[x];
        labels[x] = labels16[x];
    case 24:
        BandCutoffTable[x] = BandCutoffTable24[x];
        labels[x] = labels24[x];
    case 32:
        BandCutoffTable[x] = BandCutoffTable32[x];
        labels[x] = labels32[x];
    case 64:
        BandCutoffTable[x] = BandCutoffTable64[x];
        labels[x] = labels64[x];
arduinoFFT FFT = arduinoFFT(); /* Create FFT object */
// below is the function to initialize the I2S functionality, do not change
void setupI2S() {
  Serial.println("Configuring I2S...");
  esp_err_t err;
  // The I2S config as per the example
  const i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_ADC_BUILT_IN),
    .sample_rate = samplingFrequency,
    .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // could only get it to work with 32bits
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT, // although the SEL config should be left, it seems to transmit on right
    .communication_format = I2S_COMM_FORMAT_I2S_MSB,
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,     // Interrupt level 1
    .dma_buf_count = 2,                           // number of buffers
    .dma_buf_len = SAMPLEBLOCK,                     // samples per buffer
    .use_apll = false,
    .tx_desc_auto_clear = false,
    .fixed_mclk = 0
  // Configuring the I2S driver and pins.
  // This function must be called before any I2S driver read/write operations.
  err = adc_gpio_init(ADC_UNIT_1, ADC_CHANNEL_0); //step 1
  if (err != ESP_OK) {
    Serial.printf("Failed setting up adc channel: %d\n", err);
    while (true);
  err = i2s_driver_install(I2S_NUM_0, &i2s_config,  0, NULL);  //step 2
    Serial.printf("Failed installing driver: %d\n", err);
    while (true);
  err = i2s_set_adc_mode(ADC_UNIT_1, ADC1_CHANNEL_0);
    Serial.printf("Failed setting up adc mode: %d\n", err);
    while (true);
  Serial.println("I2S driver installed.");
//************* web server setup *************************************************************************************************************************
TaskHandle_t WebserverTask;                             // setting up the task handler for webserver                                                  //**
bool      webtoken =          false;                    // this is a flag so that the webserver noise when the other core has new data                //**
WebServer server(80);                                   // more webserver stuff        //**
WiFiManager wm;                                         // Wifi Manager init        //**
WebSocketsServer webSocket = WebSocketsServer(81);      // Adding a websocket to the server                                                           //**
//************* web server setup end**********************************************************************************************************************
//*************Button setup ******************************************************************************************************************************
EasyButton ModeBut(MODE_BUTTON_PIN);                    //defining the button        //**
// Mode button 1 short press        //**
// will result in changing the number of bands        //**
void onPressed() {        //**
  Serial.println("Mode Button has been pressed!");        //**
  if (numBands == 8)numBands = 16;        //**
  else if (numBands == 16)numBands = 24;        //**
  else if (numBands == 24)numBands = 32;        //**
  else if (numBands == 32)numBands = 64;        //**
  else if (numBands == 64)numBands = 8;        //**
  SetNumberofBands(numBands);        //**
  Serial.printf("New number of bands=%d\n", numBands);
//*************Button setup end***************************************************************************************************************************
// Below is the Setup function that is run once on startup
  //create a task that will be executed in the Task1code() function, with priority 1 and executed on core 0
  // this will run the webinterface datatransfer.
  xTaskCreatePinnedToCore(
    Task1code,                                          /* Task function. */
    "WebserverTask",                                    /* name of task. */
    10000,                                              /* Stack size of task */
    NULL,                                               /* parameter of the task */
    4,                                                  /* priority of the task */
    &WebserverTask,                                     /* Task handle to keep track of created task */
    0);                                                 /* pin task to core 0 */
  Serial.println("Setting up Audio Input I2S");
  setupI2S();
  delay(100);
  i2s_adc_enable(I2S_NUM_0);
  Serial.println("Audio input setup completed");
  ModeBut.onPressed(onPressed);
  if (digitalRead(MODE_BUTTON_PIN) == 0) {              //reset saved settings is mode button is pressed and hold during startup
    Serial.println("button pressed on startup, WIFI settings will be reset");
    wm.resetSettings();
  wm.setConfigPortalBlocking(false);                    //Try to connect WiFi, then create AP but if no success then don't block the program
  // If needed, it will be handled in core 0 later
  wm.autoConnect("ESP32_AP", "");
  Serial.println(Projectinfo);                          // print some info about the project
  server.on("/", []() {                                 // this will load the actual html webpage to be displayed
    server.send_P(200, "text/html", webpage);
  server.begin();                                       // now start the server
  Serial.println("HTTP server started");
  webSocket.begin();
  webSocket.onEvent(webSocketEvent);
// Main loop running on 1 core while the web update is running on another core
  size_t bytesRead = 0;
  int TempADC = 0;
  ModeBut.read();
  //############ Step 1: read samples from the I2S Buffer ##################
  i2s_read(I2S_PORT,
           (void*)samples,
           sizeof(samples),
           &bytesRead,   // workaround This is the actual buffer size last half will be empty but why?
           portMAX_DELAY); // no timeout
  if (bytesRead != sizeof(samples)) {
    Serial.printf("Could only read %u bytes of %u in FillBufferI2S()\n", bytesRead, sizeof(samples));
  //############ Step 2: compensate for Channel number and offset, safe all to vReal Array   ############
  for (uint16_t i = 0; i < ARRAYSIZE(samples); i++) {
    vReal[i] = offset - samples[i];
    vImag[i] = 0.0; //Imaginary part must be zeroed in case of looping to avoid wrong calculations and overflows
  //############ Step 3: Do FFT on the VReal array  ############
  // compute FFT
  FFT.DCRemoval();
  FFT.Windowing(vReal, SAMPLEBLOCK, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  FFT.Compute(vReal, vImag, SAMPLEBLOCK, FFT_FORWARD);
  FFT.ComplexToMagnitude(vReal, vImag, SAMPLEBLOCK);
  FFT.MajorPeak(vReal, SAMPLEBLOCK, samplingFrequency);
  for (int i = 0; i < numBands; i++) {
    FreqBins[i] = 0;
  //############ Step 4: Fill the frequency bins with the FFT Samples ############
  for (int i = 2; i < SAMPLEBLOCK / 2; i++) {
    if (vReal[i] > NoiseTresshold) {
      int freq = BucketFrequency(i);
      int iBand = 0;
      while (iBand < numBands) {
        if (freq < BandCutoffTable[iBand])break;
        iBand++;
      if (iBand > numBands)iBand = numBands;
      FreqBins[iBand] += vReal[i];
  //############ Step 5: Averaging and making it all fit on screen
  static float lastAllBandsPeak = 0.0f;
  float allBandsPeak = 0;
    if (FreqBins[i] > allBandsPeak) {
      allBandsPeak = FreqBins[i];
  if (allBandsPeak < 1)allBandsPeak = 1;
  allBandsPeak = max(allBandsPeak, ((lastAllBandsPeak * (GAIN_DAMPEN - 1)) + allBandsPeak) / GAIN_DAMPEN); // Dampen rate of change a little bit on way down
  lastAllBandsPeak = allBandsPeak;
  if (allBandsPeak < 80000)allBandsPeak = 80000;
  for (int i = 0; i < numBands; i++)FreqBins[i] /= (allBandsPeak * 1.0f);
  webtoken = true;                  // set marker so that other core can process data
} // loop end
// Return the frequency corresponding to the Nth sample bucket.  Skips the first two
// buckets which are overall amplitude and something else.
int BucketFrequency(int iBucket) {
  if (iBucket <= 1)return 0;
  int iOffset = iBucket - 2;
  return iOffset * (samplingFrequency / 2) / (SAMPLEBLOCK / 2);
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
  // Do something with the data from the client
  if (type == WStype_TEXT) {
    Serial.println("websocket event Triggered");
void SendData() {
  String json = "[";
    if (i > 0) {
      json += ", ";
    json += "{\"bin\":";
    json += "\"" + labels[i] + "\"";
    json += ", \"value\":";
    json += String(FreqBins[i]);
    json += "}";
  json += "]";
  webSocket.broadcastTXT(json.c_str(), json.length());
//Task1code: webserver runs on separate core so that WIFI low signal doesn't freeze up program on other core
void Task1code( void * pvParameters ) {
  delay(3000);
  Serial.print("Webserver task is  running on core ");
  Serial.println(xPortGetCoreID());
  int gHue = 0;
  for (;;) {
    wm.process();
    webSocket.loop();
    server.handleClient();
    if (webtoken == true) {
      // lets smooth out the data we send
      for (int cnt = 0; cnt < numBands; cnt++) {
        FreqBinsNew[cnt] = FreqBins[cnt];
        if (FreqBinsNew[cnt] < FreqBinsOld[cnt]) {
          FreqBins[cnt] = max(FreqBinsOld[cnt] - Speedfilter, FreqBinsNew[cnt]);
          if (FreqBins[cnt] > 1.0)FreqBins[cnt] = 1; //to prevent glitch when changing number of channels during runtime
        else if (FreqBinsNew[cnt] > FreqBinsOld[cnt]) {
          FreqBins[cnt] = FreqBinsNew[cnt];
        FreqBinsOld[cnt] = FreqBins[cnt];
      // done smoothing now send the data
      SendData(); // webbrowser
      webtoken = false;
He trasladado su tema de una categoría de idioma inglés del foro a la categoría International > Español @wixzero-yop.
En adelante por favor usar la categoría apropiada a la lengua en que queráis publicar. Esto es importante para el uso responsable del foro, y esta explicado aquí la guía "How to get the best out of this forum".
Este guía contiene mucha información útil. Por favor leer.
De antemano, muchas gracias por cooperar.
Aparentemente está mal el código fuente que has usado de base y, tal como te sugiere el compilador, lo correcto es
ArduinoFFT FFT = ArduinoFFT(); /* Create FFT object */
o sea, con "A" mayúscula.
Digo "aparentemente" porque podría ser que en versiones anteriores de la librería la clase se llamase arduinoFFT y haya sido cambiado en una actualización.
No especifica en el texto qué versión usó el autor así que más no se puede decir.
buenas, intente corregir con cambiar con "A" a ArduinoFFT FFT = ArduinoFFT();
pero ahora aparece este error:
invalid use of template-name 'ArduinoFFT' without an argument list
he notado en otros ejemplos lo declaran como
#include "arduinoFFT.h" y no de esta forma #include <arduinoFFT.h>
otro punto es que otro punto es que parece de esta forma:
ArduinoFFT FFT = ArduinoFFT(vReal, vImag, samples, samplingFrequency, true);
y en el codigo solo aparece esto ArduinoFFT FFT = ArduinoFFT();
por lo que esta incompleto
Por la fecha de la publicación deberías instalar la versión 1.5.6 de la librería pero hasta la 1.6.2 se supone que debería funcionar.
O sea, desinstala la actual e instala la 1.5.6 .
Como dije antes, la nueva versión (2.0.2) tiene bastantes cambios, entre ellos el nombre de la clase y su declaración.
Por situaciones como ésta es que siempre sugerimos tomar por costumbre comentar en el código la versión de cada librería que se incluye y, si no es desde el gestor, el link para descargarla.
Mira el tiempo que hubieses ahorrado (y yo) si el autor lo hubiese hecho
muchas gracias, esta era la solucion para este caso de proyecto, el video fue de hace dos años no se actualizo al dia de hoy, ahora estuve probando con otros proyectos pero agregando los leds ws2812b me sigue apareciendo, solo que cuando lo compilo va bien pero al momento de querer subirlo a la placa esp32 aparece el error de si es con arduinoFFT pero "A", entonces como va esto jajaja
